M
Melody Schwager Posted on Jan 02, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I buy a carousel tray for a Bell and Howell 850 slide projector?
mbarre
Level 3:
  • Master 937 Answers
  • Posted on Jan 02, 2015
mbarre
Master
Level 3:
Answers
937
Questions
Helped
311222
Points
5626
Can I buy a new Bell & Howell Slide Cube Projector?
No! They are no longer made due to the computer generation and slide presentations are usually made with laptops now. You should be able to find one good used one on eBay if interested find your model # of projector and look it up on ebay. They are usually in good condition but make sure lamp works on the one you are buying as these are expensive to replace. Rich
Lift gate tray
No. The slide tray should rotate when the forward or reverse buttons are pushed. Slides are not required for correct actuation of the tray. Before attempting any adjustment, try a few different trays (it may be a tray issue!). A 140-slide tray will be much tougher to get correct movement from than with a 80-slide tray on an older slide projector.... The 140 tray pushes the interface specification between a tray & a projector to the max.
Bell & Howell slide projector 454
go on line to bell & howell site and down load service manual or operators manual.
Kodak 850 Carousel Projector tray won't advance
The Carousel 850 is 40-45 years old. The symptoms you describe indicate the timing is off. Timing is an "adjust & test"..... try a SMALL adjustment and then test it.... adjust again & test again. Repeat until you get smooth tray action. See the attached illustration:
11helpful
2answers
My Bell & Howell cube slide projector has a strpped drive gear that rotates the slide tray. Is there any one that can help regarding parts or places that might do a repair?
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=360183793446
Bell & Howell Cube Slide Projector Gear, New Item condition: New Quantity: More than 10 available Price: US $15.00 Approximately C $15.54 Buy It NowBuy It Now
This is the gear that goes bad on Bell and Howell cube type slide projectors. If you have one of these projectors you can pretty much expect the gear in your machine to go bad. The original gears were made out of an inferior material that was too soft. New old stock gears would be made of the same material and although they have never been used they most likely will fail right away since they are made of the same inferior materal. They were made soft to reduce the mechanical noise when the gear runs. This was told to me by the person who designed them at Bell & Howell. These new replacement gears are made out of Delrin, an excellent material for gears. Delrin is sometimes used to make gears that are normally made of metal. Don’t miss your opportunity to finally fix that old projector or get a spare gear for your working machine while they are available.
Detailed installation instructions will be included with every gear.
Feb 08, 2010 • Cameras
k24674
ADMIN Andrew
ADMIN Andrew
