Question about Tablets & eReaders
My RCA tablet wont charge. I have used 4 different charge cords.
Have tried different power cords and it just ill not take a charge.
Posted by DeedraMccreless on
Jason Allsbrook
    New Friend:
  • 79 Answers
The volts may notbe the same for the chrg you have... goto bestbuy just so youcan get the right style for that model plus try can check to see if it is changing
Posted on Jan 02, 2015
My RCA tablet wont charge I have to lean it against something to charge WHY??
Help! My tablet won't turn on! what do I do?! - Asus - Android ...
www.tomsguide.com/forum/id-1869519/tablet-turn.html
Oct 17, 2015 - 50 posts - ‎43 authors
We often get questions such as " My tablet has stopped charging & I have .... Maybe the case was designed badly and the power button won't ..... Something must havelocked the Memopad open and ran the battery completely down. ..... I had RCA send a replacement tablet after it happened the first time.Missing: lean
Why can't I get my RCA tablet rct6077w2 charge or turn on ...
forums.androidcentral.com > Get Help & Give Help! > Ask a Question
Oct 8, 2014 - 4 posts - ‎1 author
Screen will not light up at all. Took it to store, got brief charge there. At home, now, no indication of power.....Missing: lean
How to Calibrate Your Mac, iPhone, or iPad Battery ...
www.macblend.com/how-to-calibrate-your-mac-iphone-or-ipad-battery/
Mar 14, 2012 - The iPad and other tablets draw more current to charge quickly then a lot of other USB devices ..... Also, it's not something you should have to do frequently. ... iPad 2 will not charge shows battery in red with electrical symbol and plug symbols flashing on ..... I'd lean against trying to restore if it won't stay on.
My samsung galaxy tab wont charge at all, why? - Ask Me Fast
www.askmefast.com > ... > Charge
Dec 06, 2015 | Tablets & eReaders
My tablet want come on what's wrong with it
I've had the same problem with my RCA 10 inch tablet. I have charged it, tried the hard reset, used different chargers and even different outlets, and held the power button on for 60+ seconds with NO RESULTS! My recommendation is to contact RCA, which is what I am doing, and request an immediate replacement if yours is still under the 1 year manufacturers warranty. If you look these tablets up, you will see (as I have found) that this is apparently a common problem with the tablets. Wish I had known that prior to purchasing!
Jan 01, 2015 | Tablets & eReaders
I tried powering up my tablet but it doesn't power up after many tries with many cords and Sears won't take it back. What is wrong?
Hi! I will try to assist you:
1. Make sure the battery is charged enough for the tablet to power on or (if it is not) if you can charge it. An easy way to do thisa is to plug in a charger and see if it indicates that it charges.
If it does not charge, then:
a) The battery is faulty or
b) Something is wrong with the adaptor or the "charge-circuit"
In order for a) and second part of b) to be checked, your tablet needs to be opened!
2. If it charges, then it might be the power button. Try to press it hard enough (try not to break it though) in order to make sure it is not a little bit broken or moved. If still nothing happens then your tablet has to be opened!
3. The screen might be faulty as well.
4. If it is none of the above, then it might be the mainboard. In order to make sure it is not the mainboard, you would need to connect it to an external monitor and see if it works with the external one (I think there is no such option in your case, though)
I assume you wish to experiment-check it by yourself. If you just need a new one, then for instance:
1result for maylong universe
Dec 06, 2014 | Maylong Tablets & eReaders
How do I fix my Toshiba tablet that won't show me that it is charging?
Have you checked the following:
  1. Power cord for breaks
  2. The power outlet you are connecting into (try at least 2 other outlets before settling, but use different outlets for the sake of argument.
  3. When was the last time you charged and it actually did?
  4. Do you have the correct cord?
  5. Have you tried to replace the cord?
Nov 22, 2014 | Toshiba Tablets & eReaders
My digital 2 tablet wont work need help asap
Hi Ashley,
Sorry to hear this. I would like to help you but need some further info on what the tablet is doing. Does any lights or sound come from your tablet when it is hooked to the charge cord or is it just a black screen? Some of these have a problem with the charge plug not connecting right so it does not get any power. Did it work fine and just died or did it have any problems before it stopped like not charging or getting errors or taking longer to come on?
I would like to help so post your response here and ill see what it could be.
Also if its under warrentee or a exended rider let them know to in case it is DOA/
Good luck and ill check on this for you
Chadman
Nov 10, 2014 | Tablets & eReaders
My android m729 tablet will not charge. I have
Trying different cords was one of the right things to try, but what are you plugging the cord into? Many laptops don't supply enough current to charge this device. You need a charger that can supply around 2 amps. Many wall plug-in power supplies ar also too low of an output to fully charge your tablet.
If you are sure that your power supply puts out 2 amps (or more) then it's my sad duty to tell you that the battery likely bit the dust. These are cheaply maid in China with the lowest quality parts, and it's all too common for then to die after just a short time.
Like I said, Try a different power supply, and f it's not that.... I am sorry.
Aug 31, 2014 | Tablets & eReaders
My tablet wont charge unless turned on but battery is so low it wont turn on so cant charge it up.heeeeeelllllpppp
You Power Cord must be bad. If you cannot get on the laptop by using just the power cord, then the power cord is bad and needs to be replaced. Also it sounds like you've been operating off your battery since the power cord is bad, but now the battery is dead because the bad power cord was not charging it.
Get a new AC Adapter and Power Cord. Or it could be that the pin where you plug the power cord into the table is damaged or broken.
May 15, 2012 | Archos 101 Internet Tablet 16GB 10.1"...
Tablets & eReaders Logo
179 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
