Question about Fisher and Paykel Dishwashers
Fisher paykel dd602 single drawer has no power. power source is good. is this a controller replacement fix?
Verified power in is good. Was working and then died. No power to display. No power to the touchless buttons
  • 33 Answers
Hold down "Keylock" switch, then "Start/{ause" for 10 seconds. This starts diagnostic mode. If nothing happens then it is indeed a power problem. Troubleshooting should start from the power plug, but will probably require a tech unless you are confident about tracing power problems.
Posted on Feb 23, 2015
5 Suggested Answers
Anonymous
SOURCE: Fisher & Paykel single drawer dishwasher F1 flashing.
F1 indicates a problem with the Flood sensor. I cleaned all the filters etc. removed the drawer viewed under the drawer, it was dry. There is nothing further I can do, so called the Appliances repair person and booked an appointment for him to determine if an outlet hose is blocked or has a hole in it or whatever. Thanks for all the suggestions Blokes. I'm technically challenged. Happy New Year
Posted on Dec 29, 2008
benham
  • 125 Answers
SOURCE: fisher and paykel leak
most likely the actuators are bad. with the unit off push and hold the lock and start buttons, lock first then start, after about 6 seconds the display will flash 188. press the power button, ho will be displayed. push the start button until Ld is displayed. open the drawer in question and push the lock button and watch the lid both sides should go down evenly, push the lock key to move it up and down as needed. push the power button to exit diagnostics. if you notice that the lid doesn't go down evenly or if one side stays up replace the actuators, they come as a pair. call a dealer/servicer to order actuators. make sure to specify top or bottom as there is a difference. hope this helps
Posted on Mar 03, 2009
Mukesh Kumar
  • 3230 Answers
SOURCE: Fisher & Paykel dishwasher model dd602 error code F4
It means your filter is dirty. Remove metal plate at bottom & scrub with a toothbrush. Clean arms as well.
Clean all around the door & pull out the lift out filter, scrub clean with a toothbrush.
Posted on Jun 26, 2009
dustymirror
  • 205 Answers
SOURCE: Fisher & Paykel DD601 top drawer won't start.
Most likely the micro-switch that tells the controller that the drawer is closed is broken. Its a tiny little black switch at the back of the left drawer slide, it had a metal actuator that is prone to breaking.
Posted on Jul 21, 2009
Linh Thanh
  • 784 Answers
SOURCE: Fisher Paykel dishwasher drawer won't stop.
Let's go to diagnostic test mode to see if you can retrieve the the actuator hence the tube out.
1- Press Lock button and start/pause key until the display showing up.
2- Press Power to show HO.
3- Press start button to advance the display until you see P2 for draining, if you pass, keep doing it to get it back in a loop.
4- When at P2, press lock to turn on, press a again to turn off.
5- Listen to the sound of the pump. If you hear nothing that means the pump is dead or stuck.
6- The Motor has 2 directions: one for, Rinse and one for Drain. When you done with the diagnostic, press the power button to get out of the mode.
7- If this is the case, unplug the power then remove the rack, the bottom stanless steel plate with holes then take out the rotor to clean up. It is a good design the stator is outside of the tube, so you don't have to worry too much about the complication.
8- Make a note of all the positions so you can put them back the same as they were. Good luck
Posted on Sep 09, 2009
Fisher Paykel DD602 removing bottom drawer
You can view the following video to check how to take the drawer out. The steps are shown half way into the video. Make sure the mains plug is pulled out from the socket before working on it.
Feb 02, 2013 | Fisher and Paykel 24 in. DS603H I Built-In...
Hello, We have a Fisher & Paykel dishwasher m# dd602 znwn showing After we fixed a hole in the drain line an F1 code still appears and the pump keeps running. What should I do from here?
F1 means that your dishwashers have flooded. You can download the video in the link below to see how to get rid of the error and fix your dish drawer for numerous other problems. If your drawer is noisy you may want to replace the rotors at this time as well.
Appliance Repair Video
Order Fisher Paykel Rotor in this link if needed
Mar 17, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
What does error F1 mean and is it expensive to fix
Hello there
The f-1 error is comng from the fflood switch meaning it is not recognizng the level of the water in the machine
First thing you need to do is pull the front panel off the drawer, :
Fisher Paykel DD602 dishdrawer with the front panel removed.
With that front panel off, pull the wire harness connectors off the main control board (lower right-hand side) to inspect for junk and debris
If nothing is found
The next step to remove the botton drawer from the unit so so you can inspect the switch itself
In order to do this, You had to remove the wire harness cover on the underside of the drawer.
Fisher Paykel DD602 dishdrawer, looking at the underside of one of the drawers with the wire cover plate removed.
With the bottom cover off, unclip the wire harness, fill hose, and drain hose. Then unclip the linkage at the back of the drawer and lifted the drawer off the slider arms. All this to expose the flood switch, shown on the left-hand side of the bottom panel in the picture below:.
Fisher Paykel DD602 dishdrawer with the lower drawer removed. The flood switch in mounted on the base, left hand side.
TAKE NOTE OF the positions of the wires on the flood switch and removing them, unclip the switch housing from the base panel. The switch housing contains one switch for each drawer. The switches are wired normally closed (NC) and each switch has three spade connections, so it's important to note where the wires went. With the switch housing out, ohm out both switches and ENSURE THEY CHECK OUT GOOD OR HAVE SOMEBODY DO THIS FOR YOU inspect the contacts and SEE IF they look oxidized or detereorated , evidenced by discoloration.
If it does look discolored clean the contacts as needed now plug in everything as it was originally and put in the drawers than run it to see if it does reappear if not you saved yourself about $300 dollars on having a tech come and do this ok
Nov 23, 2010 | Fisher and Paykel 23 in. DD603H SS...
F1 fault shows flood switch activated, how to
Hello there
This is how i did mine
saved about 300 dollars
First thing I did was pull the front panel off the drawer, batch%2010-23-04%200031.jpg
With that front panel off, I pulled the wire harness connectors off the main control board (lower right-hand side) to inspect for gookus. None found--my quest continued.
The next step to remove the botton drawer from the unit so I could inspect the flood switch. In order to do this, I had to remove the wire harness cover on the underside of the drawer. This is what the underside of the dishdrawer looks like with the botton cover panel removed:
With the bottom cover off, I could unclip the wire harness, fill hose, and drain hose. Then I unclipped the linkage at the back of the drawer and lifted the drawer off the slider arms. All this to expose the flood switch, shown on the left-hand side of the bottom panel in the picture below:.
After noting the positions of the wires on the flood switch and removing them, I unclipped the switch housing from the base panel. The switch housing contains one switch for each drawer. The switches are wired normally closed (NC) and each switch has three spade connections, so it's important to note where the wires went. With the switch housing out, I could ohm out both switches and both checked good. I inspected the contacts and noticed that one of them was oxidized, evidenced by discoloration.
and clean off the contacts. That'll restore the current flow for that circuit. ." So I cleaned the contacts and reassembled the dishdrawer. I ran the top drawer and...no F1 error code! I ran it several more times just to be sure.
May 15, 2010 | Dishwashers
Fisher&Paykel DW60 drain pump is blocked.
Check the drain hoses by removing the dishdrawers from the machine and pulling on the hoses. I installed a Fisher Paykel DD602 about a month ago and the bottom drawer was not draining. I removed the drawer and freed up the drain hose and the machine worked fine.
Feb 07, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher paykel dishwasher not draining well
Comment posted on Feb 07, 2009 there should be tabs on the sides of the drawers at the sliders near the front of the machine.
Feb 01, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
145 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Mark Davis
Level 1 Expert
Bruce Denton
Paul Bade
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
