Question about Brother SQ9000FS 80/120 Stitch & Alpha FONT Computer Sewing Machine, 8x1StepBH 7mmZZ WalkDarn1/4Foot 10Feet Theader 10Lb ExtTable 2CasesXR9000 XR9500
My presser foot lever will not go up or down.
Don't know what to do. Took presser foot off to change to another one. Now it feels like it's frozen will not go up or down at all.
Posted by M Taulbee on
MissFixIt828
    New Friend:
  • 70 Answers
Make sure presser foot shank is installed correct. The presser foot bar may also need some oil.
Posted on Jan 02, 2015
I have no tension on my singer 8734. The tension will not get tighter when I turn the know the + direction. The tread just pulls through very easily.
You must thread your machine with the presser foot UP, and here's why. There are disks that face each other on EVERY sewing machine; that is what applies the tension. Those disks are spread when the presser foot is UP to allow the thread to pass in between them. When you put the presser foot DOWN, the disks come together again and apply the tension. You will only feel tension on thread with the presser foot down.
May 22, 2014 | Singer Merritt 8734
Bernina Virtuosa 150 Presser Foot Loose
try increasing the presser with the adjuster
Feb 10, 2014 | Bernina Virtuosa 150
Presser foot lifter
foot pressure needs adjusting
Feb 10, 2014 | Bernina Sewing Machines
My presser foot "handle" is stuck on my Pfaff Creative 7550, I can't move it to use my machine. I don't see anything wrong, any suggestions?
Yikes! I bet that since it has sat for so long that you have some corrosion not allowing the foot bar to be moved.
Dec 15, 2012 | PfaFF Creative 7570
My presser foot lever wont move
it sounds like the machine needs to be serviced
May 28, 2012 | Sewing Machines
Pfaff 6091 Presser foot won't go all the way down
HAVE THE 6091 MACHINE AND THE FOOT IS NOT FROZEN BUT WON'T GO DOWN. OILING THE MACHINE DID NOT HELP AT ALL. HAD A REPAIR MAN COME TO THE HOME AND CLEAN THE MACHINE. STILL THE FOOT WILL NOT GO DOWN.
Nov 21, 2011 | Sewing Machines
Hello, just a few quick questions. I have a Janome Harmony 1017 machine and I want to know if it is an oscillating hook or a rotary hook machine. Also, I was given a rolled hem foot and a zipper foot but...
The easiest way to know is to look at the bobbin case and if it has a finger sticking up then it is oscillating, plate If you have snap on feet to take the foot off just push the front of the foot up, to put the foot on, rest the foot on the needle plate then lower the presser bar down on top of it to snap on
Aug 09, 2011 | Janome 1017 Mechanical Sewing Machine
Presser foot lever does not lift presser foot
If you can remove the cover on the left side you will see the presser foot bar. On the bar there will be a screw that may be loose. Turn the handwheel until the needle is all the way down and lift the foot manually until just before it makes contact with the needle clamp and tighten the screw on the presser foot bar.
That should do it.
Jan 07, 2009 | Sewing Machines
Model 6230- presser foot lifter won't move presser foot
That's the problem seized up use a penetrating oil from the top and work it up and down and it should free up
Dec 31, 2008 | PfaFF Tiptronic 2030
Presser foot lever won't lower the foot
This may be a lubrication problem on the presser foot shaft. Try freeing up with penetrating oil or Triflow. After letting set for an hour lower the presser foot and pull down on the ankle. If that does not work you need to open the machine and loosen the clamp screw on the presser foot shaft. Then try to twist the shaft to loosen it up.
Nov 21, 2017 | Janome Sewing Machines
Brother SQ9000FS 80/120 Stitch & Alpha FONT Computer Sewing Machine, 8x1StepBH 7mmZZ WalkDarn1/4Foot 10Feet Theader 10Lb ExtTable 2CasesXR9000 XR9500 Logo
70 people viewed this question
Top Brother Sewing Machines Experts
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
