Question about Tablets & eReaders
How come it will not connect to the wifi, it keeps saying authenticating then saved etc then authenticating and will still not go online
Posted by Laurie StPierre on
zmanky
  • 32 Answers
Verify you have typed the proper wifi password, reset wireless router
Posted on Jan 02, 2015
My tablet won't connect to WiFi,it keeps saying authentication problem
You are putting in the wrong password for that account
Feb 04, 2018 | Tablets & eReaders
Can't connect to WIFI -- keep getting an authentication problem
It depends on the tablet that you have. Usually non branded tablets tends to have lots of problem. It also could be that the radio could be corrupted. Radio is what it take care or manage the wifi, data, etc... anything with connectivity.
I do suggest that your try to flash the radio again if possible. If not, try these next steps:
1. Go tot he wifi connection and tap on forget, this is to make sure that you don't have any wifi saved.
2. Reboot your tablet.
3. Now search for the wifi again, set it up with all the requirement, like password, channels, etc.
4. Wait until it display saved even if it doesn't connect.
5. Reboot your tablet.
6. Try to connect again to the saved wifi. If it still doesn't connect, your only option is to flash the radio band.
Dec 29, 2015 | Tablets & eReaders
MY POLOROID TABLET WILL NOT STAY CONNECTED TO INTERNET. SAYS AUTHENTICATION PROBLEMS
Android tablet wifi authentication problem [Solved ...
www.tomshardware.com/.../43704-43-android-ta...
Tom's Hardware Guide
Nov 23, 2012 - 20 posts - ‎9 authors
Hello, every wireless device works except my new tablet from Acer running Android 4.1.1. ... Yes, I try to connect to the network router. ... You can hide the SSID - once your Android has it as a saved network it will ... gefraenk said: ... Hello all, I have the same authentication problem, worse, I m not sure what ...
Authentication Problem to Connect Android Tablet - YouTube
? 3:05
https://www.youtube.com/watch?v=2wul81jM7Ts
Apr 2, 2013 - Uploaded by Meroy Diniz
If you have Authentication Problem connecting you androidtablet. ... i got a different problem i cant even turn the wifi on, on my hudl 2 it blocked ...
Dec 25, 2015 | Tablets & eReaders
Will not let me connect to wi-fi it is not my wi-fi servce. it just keeps saying authentication problem
It will say Authenticating problem unless you have the passkey to the other WiFi networks. So unless its your WiFi or an open network you won't be able to connect.But you can try rebooting your device.
Apr 13, 2015 | Nextbook Premium 8 Se Android
I cannot get it connected it just keeps saying authentication problem and will not connect to wifi this is a nes tablet just purchased
Check your wifi password correctly. If you are the owner of the wifi router you are connecting try to press the refresh icon button located on the side of your router.
Mar 20, 2015 | Tablets & eReaders
How do I get wi-fi connection. I have inputted information for the wi-fi it says saved, then when you go to connect it says authentication problem and cannot complete registration.
Hi
To connect to a WiFi system, you may need 3 pieces of information:
A username
A password
An encryption key
Once you have successfully linked to a WiFi access point then your tablet will remember the settings until told to forget them.
A lot of the time you may only need the encryption key, and if the tablet detects a WiFi access point then if you tap on that in wireless settings then it will either connect automatically or ask you for some sort of code - the encryption key. If this is not entered correctly then it will return an authentication problem/error. In order to connect you have to have this code. Also bear n mind that the code may or may not be case sensitive, and that the authentication type for both router and tablet needs to be the same. It is possible that you will only be able to change the authentication type on the Aceess Point / router and not on the tablet.
Cheers
Dec 25, 2014 | Tablets & eReaders
I have a Dragon Touch tablet. won't connect to wifi after WEP is entered and accepted/saved.
Are you still using WEP security? Most devices today no longer use WEP as it is inadequate for serious security. Most devices today are using WPA2 security. If you are no using the proper security you will get an authentication error even if the password is correct.
Dec 25, 2014 | Dragon Touch Tablets & eReaders
Kindle say authentication problem when trying to connect to wifi
Im sure you would have typed wrong password. please make sure you have correct password typed.
-regards
Mar 01, 2014 | Amazon Kindle Fire HD
Authentication problem connecting to wifi
Can't get unit to connect to my home wifi , keeps giving message Authentication Problem
May 12, 2012 | Polaroid Tablet Computer PMID701
Tablets & eReaders Logo
124 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
