Trying to connect range extender
Place range extender between computer and wifi source. Dont hook to pc
Testimonial: "thanks for your reply, We have taken the easy way out and changed it for a WiFi boost."
Then you must have a standard telephone line jack, right? Does the modem have regular phone socket? If so Try using that.
Testimonial: "thanks for your help. W e have taken the easy way out and changed it for a WiFi boost."
If you don't have an ethernet connector on your computer, you can easily add one. If your system has USB ports, you can use one like this:
Cable Matters USB 2 0 to 10 100 Fast Ethernet Adapter in Black
Testimonial: "Thanks for your help but as the lead was £19.99 we changed it for a WiFi boost."
Plug the extender into the electric socket in your home.
Whatever your router name is needs to be set up on your router and the words added to the end of your wifi name. _EXT.
I set mine with the same password as my normal wifi and saved it so it automatically finds the Extender unit.
Whe
Testimonial: "Thanks for your advice but we took the easy way out and changed it for a WiFi boost."
