I am in the process of opening my above ground pool. I have a Hayward
Pro Series S180T4 sand filter. I noticed that the needle on the psi gauge reads 15 psi when the filter if off, and when I turn in on, the needle rises to 24 psi. Does the gauge need replacing or will the needle drop to zero eventually when the filter is not running?
It wouldn't hurt to replace the gauge every few years, since it makes contact with heavily chlorinated water. They are available for less than $10.
Posted on Jul 07, 2009
Your sand needs to be changed as it is clogged up with crud
The system still holds some pressure when the unit is off. It probably will decrease through time
May 29, 2013 | Hayward SAND FILTER, PRO SERIES
Jul 18, 2011 | Hayward SAND FILTER, PRO SERIES
Jul 22, 2010 | Hayward SAND FILTER, PRO SERIES
May 20, 2010 | Hayward Pro Series 18" Above Ground Pool...
Jul 24, 2009 | Hayward Pro Series 18" Above Ground Pool...
Jun 17, 2009 | Hayward Pro Series 18" Above Ground Pool...
Jun 08, 2009 | Hayward Pro Series 18" Above Ground Pool...
May 17, 2009 | Hayward Pro Series 18" Above Ground Pool...
Jun 17, 2014 | Hayward SAND FILTER, PRO SERIES
Jun 05, 2014 | Hayward SAND FILTER, PRO SERIES
523 people viewed this question
