Question about Sanyo Televison & Video
My sanyo tv picture wont come on except when you first turn it on then it goes off, the sound works
I have hooked it up to the cable tv, the person I bought it from said it was hooked up a satilite
Posted by Cherie Dovell on
Robert DeLashmit
    New Friend:
  • 26 Answers
Have you tried using a different input like a DVD or Blu-ray player with a HDMI cable? If you get the same issue using a different device and a different input then it is possible the Input board in the TV is fried, lucky all the boards in LCD/LED TV's are real easy to replace and individually are fairly cheap.
Posted on Jan 02, 2015
Sanyo 50in HDTV turns on fine, no picture or sound
How is your xbox connected to the tv? If its connected with hdmi cable. Unhook it from xbox and plug it into the back of the cable box. If nothing happens then try switching the tv input with the tv remote. Should have several different inputs. Hdmi,video,component,etc...
Feb 25, 2013 | Sanyo Televison & Video
My computer is hooked up to my tv(sanyo ds27425) thru S-video from my radeon 7500 family graphics card, it works well for awhile then the screen goes blue! sound still works and downloads still come in...
Personally I never liked s-video, especially when you have component available. But I think that the pins in the cable on one end is either real dirty, or possibly bent. There could also be foreign debris in the input/output ( TV/PC ) of the adapters. Or the cable you have just is no good. Hopefully it's not the video card itself. Try hooking up a VGA monitor and run it the same amount of time you do with the TV connected.If that's OK, try canned air in the input/output ( TV/PC ) ,and replace the S-Video cable. Good Luck!!
Mar 08, 2009 | Dell ATI Radeon, (32 MB) Graphic Card
I was watching my tv (sanyo) with cable hooked to it. The cable all of a sudden went out. I tried hooking up the dvd player and the tv is no longer recognizing the cable box or dvd player. I don't know...
sound like a tuner problem. there is a resistor that goes to the tuner that could of went bad 39,000 ohms i think which should have a orange white orang strips around it and a gold. anyway there is a problem with tuner. Sanyo was good about haveing a problem with tuners in there smaller sets. If you do not know anything about how to repair you probly shoud take to a shop but the total cost might be high and not worth it in the long run. think before you jump still water runs deep.
Mar 06, 2009 | Sanyo AVM-2506 TV
Blurry Sanyo TV
Well after playing around with the tv some more, I decided the problem was probably the cable jack, and tried running the video in/out cables thru the VCR to get around this, which I read generally works but in this case nothing. I had tried the tv on various settings, anytime I put the tv in "video" mode I'd get a blue screen and nothing else. Anyway I found a switch in the back of the Direct Tv box for ch. 3 & 4 settings. So I flipped it but still got a snowy picture, only this time it was on ch 4 instead of ch 3. By sheer accident I put the tv back in video mode while I had the satilites setting to ch 4, and the picture came up crystal clear. Since I didn't mess with it further, I'm not sure if it was the channel selector or the fact that hooked the tv up via the video cables, but whatever it was it did the trick.
I just KNEW this could not be a broken tv despite the fact that everhwere I read online suggested it was. I knew pictures can go out, or sound can go out....but to have BOTH go out didn't make sense to me. Anyway, glad its working! :)
Jun 15, 2008 | Televison & Video
Problem
You could have a bad tuner or I have found location number R106 could be open and not passing the voltage. It is a 39K resistor at half watt. The voltage goes to the tuner.
Oct 27, 2007 | Sanyo DS31590 31" TV
TV went blank and no sound while being watched
Same as mine...wiggle the connector and see if you get a picture. If so, loose connection inside.
Oct 12, 2007 | Sanyo DS24425 24" TV
Sanyo tv
Try to put DVD conection to your tv if it works normal no problem to your tv, but if sound dosnt work your tv has audio input problem maybe looseboard, or maybe you check the setting for audio.
Oct 03, 2007 | Sanyo DS13204 TV
Televison & Video Logo
55 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
