When i play games, music, even when i turn on my sounds for my touch buttons and screen its very low sound even when my volume is set at the max
This may sound silly, bit do you have your tablet in a sleeve or cover? If so, check that the cover is not covering the speaker outlet(s) on the back of the tablet. If it is, a hole or slot cut into the cover over where the speakers are located should fix the problem.
By the way, a quick test to see if this is the proble is to operate the tablet with the cover removed. If the sound is now OK, it's the cover causing the problem. This happens more often than you might think...
Also, some tablet do have really poor audio systems and both low volume and low quality sound. Hopefully your tablet is not one of them.
SOURCE: I have made sure all
I am having this same issue. I would appreciate it if someone who knows what this issue is and how to correct it would contact me and let me know what I need to do to fix it.
SOURCE: no sound rechecked setup, sound works only with ear phones, please help
I think it needs to be checked, suggest you take it back to supplier shop and get help from them.
Android 4.0 Tablet PC
SOURCE: no sound through tablets speakers
When that happens it is usually a physically defective speaker. There is a website with guides that shows you how to replace the speaker, if you can do it yourself, otherwise ask a friend or a local repair shop. The website with the guides is: Tablet Repair Guide
did you go under general settings and look at sound settings?
SOURCE: How do I get the sound on my ipad apple 16gb
Go into settings: notification center : check your apps to make sure the sound is on for that app.
