My new Bush TV has developed a problem. When I first switch it on I have picture and sound but then anything between 5 minutes an hour later I have sound but no picture.
Have already checked aerial connection. This working correctly
I searched but couldn't find anything on this. Have you worked completely through the setup menu - perhaps there is an option to disable autostandby. Good luck and let us know what you find via comment.
Hi.i had exactly the same problem with my bush 37 inch lcd tv and i took it to a friend of mine who is a t.v electrician he said it was a component in the back of the tv which he replaced and its now working fine.
TRY UNPLUGING SET FROM THE WALL FOR 1 MINUTE. PLUG SET BACK IN AND CHECK. IF PROBLEM PERSISTS TAKE IT TO A QUALFIED SERVICER. UNIT PROBABLY HAS A DEFECTIVE MAIN TOTAL ASSY.
I have the exact same problem with my tv. Unfortunately, I'm not sure what is wrong or how to fix it either. I notice your post is from July. Have you found a solution since then?
- Sarah
