Replaced the spark electrode
SOURCE: I have a two ear old Kitchenaid gas range
You will need a new igniter module. The igniter module is told to spark by the control panel. There is also a flame detection for electronic start and that could be bad too.
SOURCE: Kitchen aid KGRA 806 PSS The
Hi, This is a common issue and cannot be troubleshooted. The only way to fix this is to replace the temperature probe. The error will disappear and the range would start working fine. Please accept the solution if it's helpful. Do get back to us for any further query. Thanks for contacting fixya.com
SOURCE: hi, i have a kitchenaid
Hello &
Welcome to FixYa Please check
this parts image, you will have to test the oven temperature sensor(part#29) and door
latch(part#22) before replacing the electronic control(part#33). You can test the temperature
sensor first, if it reads between 1080-1120 ohms then it is fine and the
electronic control needs replacement. It cannot be the spark module as the stove top works fine and it cannot be the main board as oven and stove top are fine. Please get back to me if you have any
other questions. Kevin
