I have an old RCA TV and fixed the problem. Go to TV setup and Edit Channels. Under "add channel" I typed in 73 and hit "+". Could be different variations for different TVs but the solution is to add the channel. Autoprogram will only search up to channel 69 for some old TVs. Good luck. Keep fiddling until you get it.
How old it the t.v. - most t.v.s are at least 181 channel compatible..hodge-podge words..in lay terms you have to have the capability on the t.v. to support X nbr of channels...also check to see if you have the menu set at cable or air...setting needs to be on cable
SOURCE: TV Channels
SOUNDS LIKE WHAT HAPPENED TO ME WHEN THE CHANNEL GOT ACCIDENTALLY BLOCKED AS AN UNUSED CHANNEL CHECK YOUR MENU ON REMOTE FOR ADD AND REMOVE CHANNELS AND RELOAD THAT CHANNEL AS INSTRUCTS IN MANUAL FOR THE TV
SOURCE: I have a Samsung 27
Set the TV to cable tuning mode and use that channel 73. You have it set for air now so it can only tune to channel 69.
