Question about Internet Computers & Internet
I purchased a Seiki SE32HY19t flat screen yesterday it worked fine and all of a sudden there is not a network connection (wireless) but I do have access to the internet on my laptop
Richard Perry
    New Friend:
These TV's are such a POS, avoid this brand at all possible extents. no support, and useless for anything other than a dust collector. thanks seiki for nothing.
Posted on Mar 23, 2015
Linda Thurman
    New Friend:
I purchased the SE32HY19T for my daughter's room 2 weeks ago and we could set up the wireless fine (despite having a WEP-2 we learned you have to choose 'MIXED' on the tv and then it accepted our wifi password). Wifi is strong in her room, my issue is every time we turn the tv off and back on again, we have to reset the wifi. I wish there was a way to 'save' it. Any thoughts would be great. I sent an email to Seiki but no response, no surprise.
Posted on Mar 09, 2015
Lonnie Arks
  • 56 Answers
It isn't unusual for flatscreen tv to lose the wireless connection. Go through the tv's wireless setup instructions again. If it keeps losing the connection, the tv is probably near the edge of the wireless signal's ability. If that is the case, moving the tv closer to the router, or getting a better router, are really your only choices. This is assuming that the wireless in your tv is working properly.
Having said that for generic flat screen tvs, one might point out that the Seiki SE32 series is NOT "smart" and does NOT support DLNA so outside of firmware updates to the tv itself I'm not sure what else one might do with it. You could plug in your laptop via one of the HDMI ports and "surf on the big screen" as it were. If one were to check the Amazon site for this model, one would find it is a dog in this department.
If I may make a suggestion, the Visio E241i-B1 may only be 24" but it works like a charm as both a 1080P tv and a computer monitor. I bought one to temp as a monitor while changing computers and it worked mucho caliente! And it updated itself over the wireless (which is never dropped even on my less-than-ideal DSL line). The kicker? On Amazon, it is cheaper than the Seiki. ( http://www.amazon.com/VIZIO-E241i-B1-24-Inch-1080p-Smart/dp/B00HZI0Y0Q/ )
If you are really wanting a 32" I would recommend the Visio E320i-B2 ( http://www.amazon.com/VIZIO-E320i-B2-32-Inch-720p-Smart/dp/B004HG056M/ ). Same family as the 24" just bigger but only 720P (like the Seiki). But ... it's $250. As usual, you get what you pay for.
Posted on Jan 01, 2015
Marco De La Fuente Fernandini
    Habit-Forming:
  • 159 Answers
Read the owners manual from the begining.
Reset the wireless connection at Seiki.seach it again the wireless statios and add it.
MY SEIKI 32'TV SE32HY19T KEEPS TURNING OFF . IT STAYS ON MAYBE A MINUTE THEN TURNS ITSELF OFF. POWER OUTLET IS FINE AND SLEEP TIMER IS OFF. HOW DO I CHECK THE AUTO STANDBY
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
I have a 55" Seiki flat screen t.v. and after the movers moved it from my old home to my sisters house all of a sudden there is a vertical line that will not go away
It is definitely loose connection of ribbon cables connected to the TCON board.
See how to identify the TCON (Timing and Control board) and how handle the delicate ribbon cable
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
There are hundreds of video to help you identify the defects and parts if needed
1helpful
After you get tv/lap top working together can you remove the cables
That depends on how you are connecting. If you are connecting over network and both devices are wireless and connecting to the same network, then yes. But if that was the case, you likely would not have had to wire them together in the first place. How exactly are these two devices connected together?
Worked fine up till yesterday now wireless wont work
The wireless cards in the computers need to be configured with the router's wireless settings so the computers can connect to the wireless router.
Resetting the wireless router back to the factory defaults will not let the computers connect to the wireless router without configuring the network card in the computers with the router's wireless settings.
I suggest you configure your wireless router with encryption settings to prevent unauthorized persons accessing your wireless network and Internet connection and your computers.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
1helpful
I purchased a Sony Bravia EX710 (46 inch) TV yesterday. It works fine except I cannot get the wireless adaptor (which is plugged into the USB drive) to connect to the internet. I have entered the access...
I believe you have entered Access PIN for the network but check at the same time if you have entered user name password for your internet service provider.
Reply if you are able to resolve the issue
1helpful
My laptop can detect my network but unable to connect
1) double click on the wireless network icon on the status bar
2) click on View wireless network
3) click on change advance settings
4) go to wireless networks
5) under the preferred networks, remove the SSID
6) try to connect again
Advent 4213 netbook not connecting to wireless network
Have you entered the security details regarding your network connection into your new netbook.
Sounds like the problem.
Detect the network and enter the security key (WEP;WAP etc) and should work
Network has suddenly dissapeered
This is just a problem with the wireless settings of the router, you can try first to reset the router by pressing the reset button for 20 seconds while power is ON and then after that you should be able to find the default wireless name of the router which is linksys, after you reset the router just need to reconfigure it back...
Wireless Connection for Laptop
i assume youre talking about plug n play and not built in wireless.
in your sys tray(bottom of screen) youll see a icon of your wireless connection(blue when connected,red cross on when not) double click on it and select properties.in new window select wireless networks.in new screen uncheck use windows.click ok.you may have to configure is so let me know
Router issues?
If you haven't made any changes and suddenly your wireless connection has stopped working than these are the signs that your router is offline.
Now first of all check that on your router have you got the dsl or the internet light solid if it's not solid then it could be a problem with your broadband line...check with your isp whether the signals are there on the line or not.
Now, if the signals are there then...
1) Do a complete power cycle of your router unplug all cables from your router replug them then check....
if still you are not able to open up any pages on ie...then reset your router to default settings...
in order to reset your router at the back of your router you will find a small hole that is the reset hole press the pin in that hole for 10secs that will reset your router....restart both of your comps....
Now, if you are using windows xp then
click start>control panel>in control panel click on switch to classic view>after that click on network connections>
in network connections you'll find wireless network connections....right click on wireless networks..
then click view wireless networks you'll get an option of belkin wireless network..select it and press connect....
once it says connected close all the screens and run the router installation disc that you got with your router .....you will be able to connect..
If you are on windows vista then
click start>then in start menu click connect to you'll find belkin network select it and press connect once connected run the router installation disc...
Computers & Internet Logo
Ekse
 Francisco Mauricio...
 Grubhead
Grubhead
