The OTG adapter is not guaranteed to work with all tablets, or peripherals. It has to be enabled by the manufacturer. having said that, If the supplied keyboard doesn't work directly, then It sounds like the tablet, or keyboard, is busted.
I don't have one of these but the keyboard should plug directly into the tablet. The OTG adapter is used to attach USB storage like a flash memory stick. Have you tried charging the keyboard?
Just a wild guess; You could also check in Android settings - Language and input - keyboard... plug in the keyboard and you might see an option to use an external keyboard (but that's just a guess)
Not sure on you particular model but most tablets have 2 mini USB ports one has a power supply and the other is just an I.O port .
Try your keyboard in the other port if you have one and it should work. If not it may be faulty.
HTH
