Refrigerators Logo
J
Jennifer Toon Posted on Jan 01, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Left door of F/P fridge part for a week. Now red light is flashing, beep stopped but fridge not cold enough.
Fridge was beeping after door of top part being left open for a week. Beeping stopped but light is occasionally flashing red for temp control. Freezer is down to minus 12 fridge part not below 0. Should I turn it off and defrost?
Peter Goodwin
Level 3:
  • Refrigerators Master 744 Answers
  • Posted on Jan 01, 2015
Peter Goodwin
Level 3:
Answers
744
Questions
Helped
366158
Points
2777
Hello Jennifer;
My name is Peter. I am a retired field service refrigeration technician.
No. Your problem is not defrost.
The normal temperature setting for a freezer is -2 to +2 degrees F. or -18.8 to -16.7 degrees C. The fresh food section should be set at 35-40 Degrees F. or 1.6 to 4.4 degrees C.
Reset your temperature controls to the recommended settings.
Up plug your unit for 10 minute to power down. Plug your refrigerator in.
1helpful
Panel on the left door lights up and beeps like the door is open too long
MY MONEY WOULD BE ON THE DOOR SENSOR,, BUT COULD ALSO TRY UNPLUG AND DEFROST FOR 24 HOURS AS MOST SENSORS TEND TO PLAY UP WHEN TOO COLD OR FROSTED
3answers
My door alarm on Kenwood fridge/freezer beeps when I close the door and freezer temp flashes -88 before going back
I have a Kenwood tall fridge (KTL60X15) which developed similar faults. It was beeping every time the door was opened (the display showed 88 and all other buttons were lit) and it would beep again when closed. Turns out the wiring from the fridge body to the door had worn out and by the time I discovered the problem 3 of the 5 wires had broken. The wiring can be round under the plastic covers at the top of the door and at the top of the fridge body.. I replace the wiring which was easy to do as it comes as a wiring harness kit (HK1495740) and adjusted how the wiring goes across the top hinge by making a small modification to the plastic covering on the top of the fridge body. So hopefully it won't wear out (at least now I can see it and keep an eye on it).
I have an LG e522b. Came home to it beeping after holidays. Left it off for a week. Continues beeps when powering on. Temp cont flashes on freezer. But otherwise fridge works still. Beep stops when...
It would seem that a bad sensor somewhere is causing this malfunction. So check all the sensors including thermostat, temperature and door sensors cheers
Beeping alarm every 6 hours like most posts here, top of fridge not getting cold enough10C ... but
beeping alarm every 6 hours like most
posts here top of frigde not getting cold
enough10...but
Hi, I have fisher and paykel E522BLX bottom freezer fridge. It is making beeping sound sometimes when I open the door. It also has green light flashing on the control panel all the time. Both fridge and...
beeping when door is open is one of its features the flashing light means someone has tried to set something and not completed the selection just try pushing one of the buttonstill it stops
Refridgerator E249T the beeping alarm wont stop. The door appears okay. How can I disconnect the alarm, please? Thanks Brian
I have the same fridge. It was driving me crazy. I emptied it. Cleaned it. Defrosted it. And was ready to dump it. Then worked it out. As it beeps when the door is open. How does it know. Because when the door is open the light is on. I taped up the light nob with masking tape, on top left of fridge. No light now
But no beep Yay!!!!
9helpful
2answers
Fisher & Paykel Fridge Freezer E402B beeping when door closed
If the cabinet is warm inside it is a failed circulation fan, failed defrost causing the evaporator to freeze up, or it needs a refrigerant gas top up.
Beeping is just an alarm. It may be because of the more serious issues listed above but can also be caused by a failing door gasket, the door being left ajar (kids are famous for this) or the door has been left open too long deciding what to have for dinner.
I hope that answers all 8 of you :>D
Help here
https://www.google.com/search?q=fisher+and+paykel+fridge+beeping+with+door+shut
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
