Question about Rival VS107 Seal A Meal Vacuum Food Sealer
Seal-A-Meal will seal but not vacuum out air
We have placed the end of the bag in the drip tray, closed the lid, pressed down, the sealing begins, but the air is not removed. The bag is sealed with air, defeating the purpose. We have followed manual instructions, but with no solution.
Posted by Joan Willett on
4 Related Answers
GetMeOttaHere
  • 2926 Answers
SOURCE: Hi I have a RIVAL
Bag will not seal
• Check that there aren't any gaps, folds, wrinkles or holes in pre-sealed edges.
• Moisture of foods with high liquid content will prevent the bag from
sealing properly. Cut bag open and wipe top inside of bag and reseal.
• Make sure you've placed the bag in the proper place. When making a
bag from a roll, make sure end of cut piece is on Sealing Strip, NOT over
Lower Sealing Gasket or in Drip Tray.
• Make sure you give the appliance time to cool down. Wait at least 20
seconds between seals.
If all the above have been verified and the machine will still not pull a vacuum, you will need to replace the upper and lower gaskets.
Posted on Dec 22, 2010
Ed Mac
  • 731 Answers
SOURCE: when vacuuming out air, the
Try placing a folded paper towel in the bag between the item and the area of the seal
The towel will absorb the liquid allowing the bag to seal but keeping the liquid in the bag
Posted on Feb 05, 2011
pdarrach
pdarrach
SOURCE: When I go to SEAL, it burns a small hole clear thru the bag. One little metal peice on the sealing strip has burned right thru the white heating strip, therefore, it isn't sealing completely.
You need new tape to replace the one presently covering the heat element. You can get a roll of it for just US$7.99. Look at the FixYa question "where [or how maybe] can I get a new tape." I think that you have to be sure that the heat element is flat. I bought a used unit with that problem and the element had somehow gotten bent. Ordered the tape this morning and the cost is worth the hopeful fix.
Posted on Oct 02, 2012
pdarrach
pdarrach
SOURCE: Seal-a-Meal seal has blister on it
I think that you have the same problem that I have. The protective tape over the heating element [a strip in my case] has a hole in it and allows the element to come in direct contact with the bag. Also, the heating strip had a kink in it was was no longer flat. I carefully cleaned the heating strip and flattened it out as best I can. I have ordered some tape from : http://www.ebay.com/itm/170848027703?item=170848027703&viewitem=&sspagename=ADME:X:AAQ:MOTORS:1123&vxp=mtr to replace the defective one. A simple job.
Posted on Oct 03, 2012
Not sealing the bag
My husband is a fisherman here in Key West and swears by his vacuum sealer, but he was about to throw it through the window last week when it stopped working.
The motor would just run and run, but the vacuum never kicked on.
I found an answer online that solved his problem and may help some, but not all of you.
Apparently, it was all about bag placement for us.
When you're just trying to seal one end of the plastic to make a bag from a roll, make sure the end of the plastic is just on the front, flat heat seal strip and is NOT touching the black, rubber gasket that lines the vacuum tray, Also, make sure the end is NOT hanging over the gasket and into the vacuum tray.
Apparently, the machine was sucking, but air was constantly come through the other, open end.
Once you've sealed a bottom into your bag and have added your contents, then you put the open end (after making sure it's dry) all the way into the vacuum tray.
Hope this helps, good luck! I was so happy to find an answer online that I figured I'd share it with others.
Here's to fresh fish!
Mar 30, 2014 | Rival VS230 Seal A Meal Vacuum Food Sealer
Why does my rival seal a meal not seal?
The sealing mechanism is not working properly. Make sure there is no debris in the path of the seal wire - if so the area under that material will not be sealed and there will be leaks.
Sep 15, 2017 | Kitchen Appliances - Others
Unit will not heat and Hand free light will not come on.
My husband is a fisherman and swears by his vacuum sealer, but he was about to trthrow it through the window last week when it stopped working.
I found an answer online that solved his problem - apparently, it's all about bag placement.
When you're just trying to seal one end to make a bag cut from a roll, make sure the end of the plastic is just on the front, flat heat seal strip and is NOT touching the black, rubber gasket that lines the vacuum tray, Also, make sure the end is NOT hanging over the gasket and into the vacuum tray.
Oct 24, 2011 | Rival VS230 Seal A Meal Vacuum Food Sealer
Stopped sealing the bags, does not vacuum 3 week old machine
Did the clip break that holds the sealing nozzle in place? If so, use a chopstick to hold the lock and seal unit in place. I place a little scotch tape on the chopstick, place it all the way across the sealing nozzle. You may have to really press on the lid to shut it, but it works. If it's not the clip, maybe you have a blocked hole or the sealing unit needs cleaned out really well. Good luck!
May 05, 2011 | Rival VS230 Seal A Meal Vacuum Food Sealer
When vacuuming out air, the liquid is vacuumed, inside of the bag where it seals is wet, and it won't seal.
Feb 05, 2011 | Rival VS230 Seal A Meal Vacuum Food Sealer
I purchased a Seal-A-Meal roll to make my own bags but can't figure out how to use it. I have a model VS108. Is it possible to seal without vacuuming?
On most models of vacuum sealing systems, you cut off the roll the size of bag you need. Slip one open end of the bag just on top of the heating element over it about 1/8-1/4" and press down the lid to seal the bottom of the bag. Fill the bag and then place the open end far enough into the vacuum cavity over the heating element and close the lid and press down and hold until the cycle finishes. If you don't want a vacuum, just put enough bag material to cover the heating element but not into the vacuum cavity. Hope this helps
Jan 03, 2011 | Vacuums
How do you make a bag from a roll for a vs240
place the end of the roll just past the wire heating element into the sealer and press and hold the lid closed until the cycle finishes. (I usually do this twice in a slightly different place). Remove the roll and cut the plastic back far enough into the roll for the bag you are going to fill. Leave enough space to seal the bag after you have filled it. Seal the filled bag according to the instructions.
Dec 29, 2010 | Rival VS230 Seal A Meal Vacuum Food Sealer
The small white clip that keeps the nozzle cage dowmn is broken. Can i get it replaced?
Mine broke too.. I contacted Seal-a-meal, and for my machine, they don't make replacement parts anymore. BUT, here's what I did and it works great. I place a chopstick across the length of the lock and seal nozzle...I use a little scotch-tape to hold it in place.. When you shut the lid, it applies enough pressure to the nozzle, to start pulling air out of the bags. I do have to lean or push down hard on the lid, to get it to lock into place, before sealing, but the chopstick works wonderful...I am not going to buy a whole new seal-a-meal when this works so terrific. In fact, I just seal-a-mealed 8 bags of beans this afternoon. Try it before you go out and buy another machine.
Nov 30, 2010 | Rival VS230 Seal A Meal Vacuum Food Sealer
How to operate a Salton vacuum bag sealer?
HOW TO MAKE A BAG
1. Place the BAG SEALER on a firm level surface adjacent to a power supply socket. We suggest the bag sealer be positioned away from the edge of the work surface allowing plenty of clear space for making the bags.
2. Take the polythene roll and insert it in the trough in the sealer, positioning it so that the film is pulled of the roll from the underneath.
3.Polythene roll supplied by Salton (Cat No. 1121) is a high grade film suitablefor use in a microwave oven, boil-in-the-bag cooking and for storing in the freezer. Replacement rolls are obtainable from stockists, or in the case of difficulty, from Pifco Servive Department.
4. Plug in to mains supply socket and switch on.
5. To make the first seal on a new roll of polythene, lift up the cover and pull out enough film to project an inch (2.5 - 3 cm) or so outside the casing.
6.Now press the lid down firmly so that both the red and green indicator lights come on. In a short time - approximately 6 seconds - the green seal light will go out. AS soon as this happens lift the lid and peel of the film.DO NOT ATTEMPT TO PEEL THE FILM AWAY BEFORE THE GREEN SEAL LIGHT GOES OUT.
7.NOTE - when closing the lid and applying pressure two distinct clicks will be heard.
theses are the switches which operate the two functions of the BAG SEALER.
First click - Operates the air extraction motor. Vacuum light (RED) ON.
Second click - The sealing wire is energised. Seal (GREEN) and vacuum light (RED) both on.
8. We suggest that you famillarise yourself with the pressure mechanism before you begin using your BAG SEALER. It is perfectly safe to operate either the seal or vacuum functions with out using any polythene roll.
9. After several uses deposits of polythene on the sealing wire can reduce the effectiveness of the seal. Theses deposits of polythene can be removed by operating the seal mechanism without any polythene across the wire.
10. Having sealed one side of the bag, pull out the film to the desired bag width (MAXIMUM WIDTH is 2.9 cm / 11 1/4 inches) and seal again by closing the lid and pressing down hard.
11. As soon as the Green seal light goes out, lift the lid and peel the bag away. Ensure no film adheres to the sealing wire.
12. This seal creates your first bag and at the same time the first seal for the next bag.
SEALING A FILLED BAG (WITHOUT AIR EXTRACTION)
1.Make sure that no food or liquid remains in the top portion of the bag close to where the seal will be made as this may effect the effectiveness of the seal.
2. Place the open end of the of the bag over the sealing wire making sure that the film is flat WITH NO FOLDS OR CREASES ALONG THE LINE OF THE SEAL.
3.Close the lid and press down firmly to make the seal.
EXTRACTING AIR FROM A FILLED BAG.
REMEMBER: Do not extract air from bags containing liquid !!!
1. After filling the bag and making sure that the sealing area is free from food particles, place the open end of the bag over the sealing wire and place the black air extraction nozzle well inside the bag. It is important to ensure the the two edges of the bag under and over the nozzle are straight and not creased in any way to ensure an air tight seal !
2.Depress the lid gently until the red light comes on and hold this position to operate the air extractor. (DO NOT press so hard as to activate the the green light and therefore the sealing wire).
3. As the air is being extracted it is sometimes of help to hold the bag with your hand and gently move the contents around to help channels of air to form, so aiding extraction. Depending on the the nature of the porosity of the food some unavoidable air pockets may form but moving the contents around these can be minimised.
4.Once all the air has been extracted increase the pressure on the lid until the green light comes on. This must be done in one continuous movement, otherwise the air might seep back into the bag. Once again the bag should not be pulled away from the bag sealer until the green light goes out. Pressure on the lid should be released, the lid lifted and the bag peeled away.
LAMSBREAD :)
Sep 27, 2009 | Kitchen Appliances - Others
Seal-a-meal won't seal
Take apart and see if wires are connected That is what was wrong w/ mine. Soldered wire now works fine.
Mar 30, 2008 | Vacuums
Rival VS107 Seal A Meal Vacuum Food Sealer Logo
80 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Michael Thomas
Michael Thomas
Paul Carew
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
