Question about MTX Car Audio & Video
Where can I find a manual for a MTX Black Gold 2125 amp?
Google
Posted by Farley Philogene on
Robert marquette
  • 102 Answers
Go MTX's website
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Posted on Jan 07, 2015
1 Related Answer
gopakumarg43
  • 76455 Answers
SOURCE: need manual for mtx audio thunder 4501
Hello
Get into this link. You can download the user manual to your device from here. OK.
caraudio.manualsonline.com/manuals/.../mtx_audio/mtx_audio_car_s
Posted on Jan 14, 2012
I need to know value of 2 resistors r428 and r429
Here's your answer! Black, Maroon or Red, Black and Gold! look at the pics, If you could please tell me the value of R408 I believe? its next to R415 near the Power on Diode.
Feb 07, 2013 | MTX RT2200 Car Audio Amplifier
How do I wire my 12inch mtx ts 55 subwoofer two outlets red with red and black with black or red and black and red and black
The TS55 is a DVC subwoofer that can be wired for either 4 ohms (voice coils in series) or 1 ohm (voice coils in parallel). The appropriate wiring depends on the amp.
If the amp is stable at 1 ohm, wire both positives and both negatives to the matching amp output terminal (parallel) as shown in Wiring Option #1.
If the amp isn't stable at 1 ohm, connect a jumper between the positive on one voice coil and the negative on the other voice coil. Then connect the remaining positive and negative to the matching amp output terminal (series) as shown in Wiring Option #2.
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=1&woofer_imp=3
Jun 17, 2011 | MTX TS551022 Car Speaker
I have a phoenix gold ms-2125 and need to know what is the ohms on the resistors
What resistors about you talking about? The amps resistors are internal. Are you trying to replace the internal ones?
Apr 13, 2011 | Phoenix Gold Limited Edition MS2125 TA...
How many watts is a white phoenix gold ms 2125 triple darlingtion high definition amplifire
into 4 ohm 13.8 volts 160 watts rms x2 2 ohm 13.8 volts 255 watts rms x2bridged 4 ohm 13.8 volts 510 rms
hope that helps or follow link to manual
http://download.phoenixphorum.com/Manuals/Amplifiers/MS_MAC_Amps/ms2125.pdf
Aug 15, 2010 | Phoenix Gold Limited Edition MS2125 TA...
Ran it at [email protected] now it has low power
Hello if your amp is the one above in the picture, MTX-1501D then your amp is not 1 ohm stable. Your amp is rated at 500 watts x 1 at 4 ohms and 1000 watts x 1 at 2 ohms. The amp has a safety circuit that if it senses to low of a load, ohms, it will only put out half it's power to protect the amp from shorting out. Read the manual. You can download it at retrevo.com or just google it and a manual download site will be in the search list. Hope this hels, Good luck.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
Aug 21, 2009 | MTX Thunder 1501D Car Audio Amplifier
MTX 1501 SCHEMATIC DIAGRAM
MTX never released any of their schematics.
What sort of problem are you having with it?
Sep 29, 2008 | MTX Thunder 1501D Car Audio Amplifier
Wiring my subs to my amp
bridge it and rear channel if you need to know how to bridge let me know
Feb 07, 2008 | Phoenix Gold Octane-R 15.0:1 Car Audio...
Ground Wire Hook-up
MTX has the hookup diagram here: http://www.mtx.com/caraudio/products/manualsQuickInstall/amps/RTP251D_InstallSheet.pdf If you have the original wiring harness, the ground wire is normally black. The amplifier case or chassis is ground connnected on amps I've seen as well.
Aug 06, 2007 | MTX Thunder 251D Car Audio Amplifier
Car Audio & Video Logo
94 people viewed this question
Top MTX Car Audio & Video Experts
Marvin
Marvin
Tom Chichester
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
