Depending on the way the lights are flashing you could be able to fix this reasonably easily.
If the lights are flashing at high speed together (ie: at the same time) then it's a fatal error and the chances are you have some kind of problem such as:
- paper jamming up the works
- loose wiring
- the cleaning station sometimes pops up out of position and stops the printhead getting back into the parked position. If this is the cause you have to push the white wiper plastic down and to the right before allowing it back up and into the mated position with the parking pad. Takes a little work but it's easy enough.
Problem #2 is the waste pads and that's indicated by the flashing lights alternating rather than together.
If it's this then rather than reinvent the wheel (I've posted about this soooo many times now) here's a helpful little guide here:
http://www.octoink.co.uk/store/pages/Epson-C86.html (the C86 is the same as the C88 in terms of the waste pump/tubing design)
Resetting the waste ink counter requires the SSC utility from ssclg.com or a suitable adjustment utility which can be found for download if you search hard...
Hope that lot helps but if you get stuck, post again and I'll do what I can.
Cheers,
Martin
