GPX Hm3817dtblk Home Music Hi-fi System - Cd Player -hm-3817dt- Logo
J
Judith La Placa Posted on Dec 31, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I reconnect the two small speakers to my system if they have been cut off from the actual speakers?
At one point I cut the speaker wires to connect to another type of speaker. Now I have two bare wires with no male connectors on them. Please help
Tom M
Level 2:
Habit-Forming:
Scholar:
  • Expert 90 Answers
  • Posted on Dec 31, 2014
Tom M
Expert
Level 2:
Habit-Forming:
Scholar:
Answers
90
Questions
0
Helped
22049
Points
206
Need more info to know exactly, but new connector jacks can be soldered on to the bare wires. RCA jacks are most common. Just make sure wiring is soldered same way for both speakers - normally each wire pair is marked with one of the pair being plain, the other having a stripe or dashed line printed on the wire insulation or jacket. Some may use a coax type of wire that has center wire and a braided wire between the center wire and the outer jacket. Normally with coax, the inner wire solders to the center pin, the braid to the outer contacts. For the two wire pairs, make sure you solder the same way, solid color to pin, striped wires to outer contacts. As long as the jacks are soldered the same way to the wires,you should be ok. If your wiring is different that described, then more details will be needed. Attached photos if possible.
Mikey
Level 3:
Top Expert:
  • GPX Master 6,903 Answers
 Mikey
GPX Master
Level 3:
Top Expert:
Answers
6903
Questions
5
Helped
1620603
Points
26101
If you need to connect new male connectors to the wire ends you can get them from any good electrical shop! Some are solder-less connections or if you are handy with a soldering iron you can do a proper job on it!
Testimonial: "thank you Mikey. I can splice these wires then?"
  •  Mikey
    Mikey Dec 31, 2014
    Not sure what you mean by splice? Normal speaker wires will have positive and negative sides, if you mean you want to join the 2 speakers into 1 connection then that is ok! Obviously pair the positives together!
Pioneer receiver overload
The "Overload" message usually involves the speakers or the speaker wires. Disconnect the speaker wires and make sure that they aren't frayed or damaged. (When you reconnect them, make sure that no loose wire touches the receiver case, speaker or another wire.) Replace any damaged wire. Make sure that none of your speakers have a lower impedance than the receiver can handle. (Most Pioneer systems have a 8 ohm limit.)
If the message persists, turn off the system. Disconnect one speaker at a time and try turning on the receiver and turning up the volume. If the error disappears when one speaker is removed, that speaker may be damaged and needs to be serviced. Do not reconnect the speaker to the receiver until it is fixed.
I hope this helps.
2answers
1helpful
2answers
My Denon AVR 1010G displays "PROTECTION!!!" AND cannot function further more. How to make it function properly?
The most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
1helpful
My system is turning off on its own and right before it turns off it says protection. Why?
1helpful
Stereo cuts off when volume is turned up
The most common problem found on FixYa for Audio Video2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire2_bing.gif. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers2_bing.gif) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
1. AFTER TURNING UP THE RECEIVER THIS ONE TIME AND IT CUT OFF. 2. NOW EVERYTIME I TURN IT ON AFTER A FEW SECONDS IT GOES TO STANDBY MODE
1helpful
When I turn the system on it flashes ''PROTECT''
2helpful
Protect signal comes on and receiver cuts offafter about 4 minutes of use
Where can I get a speaker wiring chart for 97 Ford Explorer
Perhaps there was another system installed at another time and someone cut the wires within the system to make that particular stereo system work. Inspect the wires all the way from the decks wiring harness to the speakers, they could be cut and you might be able to splice the wires and reconnect them or you may have to run seperate speaker wire for each speaker to resolve this issue.
18helpful
3answers
Rear door speakers don't work w/ aftermarket radio in 94 suburban
You need to attach the blue wire on the stereo harness to the blue and white wire on the car adapter harness. they installed a small amplifier to power the rear door speakers and unless you connect those two wires then the speakers will not work.
Top GPX Audio Players & Recorders Experts
SmartAviator
SmartAviator
 Grubhead
Grubhead
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
