Question about Samsung Cell Phones
I have Samsung 6272 when I charged the phone is full after 5 minuts I change the batter and charge but m problem not soluve ?
I tired so far that This phone is not good for use
Posted by sartajkhan on
Bryan Tricker
    New Friend:
  • 4 Answers
The very first charging-time of the battery should most-usually last 6-8 Hrs , and if you did not do the same i suggest you drain your battery to the bottom until it turns off by itself , then plug in the charger and leave it charging for 8 hours (meanwhile the phone should be turned off ) . should be fine after ;D
(in case you did everything as you should and encountered this problem long time after you using the phone , all you can do is replace the battery)
Posted on Jan 02, 2015
What is wrong with my samsung galaxy s3?
Before buying anything, back up your S3 data using Samsung Kies. Then do a factory reset.. followed by a data restore..
firmware updates can cause problems until the handset is reset, as parts of the previous firmware are still in use..
You should notice an improvement after this... mine went from half a day, to almost 2 days usage, just by doing this after a firmware update.
My samsung GT-E2220 is not charging and wont switch on or off what can the problem be
It could be due to many reason, such as,
1. Battery completely drained.
2. Charging port is not working.
3. Mobile Operating System Problem.
4. Charger not providing the right voltage to charge the phone. and many more....
Remove the batter and clean the charging plates with some cloth, now put it in and connect the charge and leave it for 30 minutes if you still can switch it on, replace the battery and check if the problem is hardware of operating system related.
Cheers!
Nokia 2310
remove the battery for about a few minutes and restore it to factory default settings. Full charge your battery after that.
thank you for using fixya
CHARCOIS
Battery runs down fast.
hello there....well its quite simple...
how old is your phone ?
i am assuming its an old phone so it is time to change the battery...you will see that batter is slightly puffed or out of shape ...in that case you should immediately change it
if its a new phone....then check if blue tooth is on or off....it should be off....and if you use the phone a lot then also the batter will run out in 3 hrs and 30 minutes of talk time...playing music as well as keeping the camera on for a long time will drain the batter
so it depends on how you use it ....if you have more question we will take it from there
Hope this help
Cheers
HANGING
u must try to change its battery
2answers
Purchased new battery, now NOTEBOOK won't work on battery after full charge
Better you first charge the battery for 16 to 17 hours and recheck the same. If problem persists, change the battery from where you bought it. that battery is faulty. And yes there is no need to install the battery from device manager. Just open the battery compartment and replace the battery with new one.
Wont open
try to replace your batter.
Battery charging
there are two things mainly, first ur battry is weaken now or ur charger can have problem also ur phone can have problem with in itself better u take it to technician so it can be checked for exact fault and can be repaired.
Cell Phones Logo
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Tim Whalen
Muzahura Frank
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
