Question about Proscan 50" LCD HDTV PLCD5092A - CURTIS INTERNATIONAL LTD
How do i get warenty work done on my 50" proscan tv. i bought it at K mart. Do i take it there ?
Nothing yet but if i touch the backof if to controls the tv screen goes black
Posted by james mcdaniel on
Brett Duxbury
  • Proscan Master
  • 4,290 Answers
Suggest phoning kmart store and asking them where the nearest warranty repairer would be for the tv.
Posted on Dec 31, 2014
5 Related Answers
karcarsign
SOURCE: On my proscan tv, when i turn it on the sound
i think this is a known problem....some guy in phoenix is selling a bunch of these returned tv's from SEARS with the same problem for $150.00 try to return it.
Posted on Apr 22, 2009
Anonymous
  • 245 Answers
SOURCE: My Proscan 19LA20Q Keeps going to sleep mode
ur sister possible turned the sleep mode on.......check on ur remote that is is off......if this problem persist u have to call service to fix ur problem
Posted on Nov 20, 2009
Anonymous
SOURCE: I need the remote control code for Proscan tv with dvd player
Don't know if the 26" is the same as the 32, but 10019 works for the 32".
Posted on Jan 18, 2010
panchal643Ja
Jayesh Panchal
  • 279 Answers
SOURCE: i bought a proscan lcd tv/dvd last yr & have
Please select Source Button from your LCD remote to change source and select any other source or select DVD mode.
Posted on Feb 19, 2010
gopakumarg43
  • 76432 Answers
SOURCE: My Proscan led TV (PLDED3273A) is switching color from red, blue, green, white, and black.
Just do a hard reset to this set and check. To make it a hard reset, unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If this do not help you, the main board to your TV is faulty. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Posted on Apr 01, 2014
My remote control broke, and I bought 2 different universal remotes that will not operate the tv.Do you know why? The model number is PLDED3273A-B
You should set it up with the set-up code to your TV brand; with the codes said to it in the code list of the remote control. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 22, 2014 | Proscan Televison & Video
Proscan tv manual
  • Where can i get warenty info for my proscan 50" tv
Jan 02, 2014 | Televison & Video
I need to buy a new or used base for my 42 in proscan lcd tv.
Other than going to Thompson who is RCA/GE/Proscan you can Google the model number with base to see what is available.
Dec 10, 2012 | Proscan 42LA45H 42 in. LCD TV
I bought my 19" Proscan LCD (19LA25Q) used from a
The Proscan 19LA25Q came with a remote originally. Unless the IR receiver has failed, it should work with a universal remote. (Note: if the TV is newer than the remote (or released less than 6 months before the remote was programmed), the remote codes for your TV may not be included.) Since the code lists on universal remotes do vary depending on the age and model, please give more information than just the brand. GE remotes usually have a version code label in the battery compartment. This version code is needed to look up the correct code lists. Some GE universal remote built by Jasco codes are here: https://byjasco.com/support/ge-universal-remote-codes.
The Proscan 19LA25Q was probably built in 2007, since there are reviews from 2007. That was also the year when this size TV had to have an ATSC tuner. So if your remotes were programmed before July 2007, they may not be compatible. Some of the current Proscan TVs probably use the same parts as some Sylvania, RCA and Curtis TVs.The 19LA25Q was warranted by On Corporation which has control of the RCA brand now. However, I don't know when they bought the label.
Amazon lists a few direct replacement remotes for the 19LA25Q. See https://www.amazon.com/Original-Proscan-Control-E20F-19LA25Q/dp/B00KQVDRNK and https://www.amazon.com/PROSCAN-Replacement-Remote-Control-19LA25Q/dp/B009H5QVIO . Remotes.com also has a replacement remote: http://www.remotes.com/SearchResults.asp?Search=19LA25Q .
I hope this helps.
Apr 21, 2017 | Proscan 19LA25Q 19 in. LCD Television
My family just bought the dynex 1080 from best buy saturday and today myfather can't even get the controller to get the volume to higher or lower or can't even get the tv to turn on or off what is the...
TAKE IT BACK!!! If you can. Many problems w/Dynex.Esp. Now they are no longer in business.
You can not get parts for them.Your remote problem may be a stuck button.Try pushing each button.Sometimes the rubber sticks if the remote is new.Battery may be bad or not making good contact.Take the batt.cover off and roll the batts. Also take the batts.out and push the buttons on the remote,then replace the batts.some times that works.But if you can take it back to Best Buy.And get another TV. Stay away from off brands. Also RCA are junk,not the same compant. I have too many in the shop to count even if I count with my toes. Samsung ,also Vizeo great for the price."basicly a lower end of LG"If you can't fine a decent priced TV at Best Buy,Try Wal Mart. But on all these new TV's,you need to buy the warenty.They still have alot of bugs to work out.That is about 98% of my business.Doing the warenty repairs in central FL.
I hope this helps you out. todd
Oct 27, 2009 | Dynex DX-LCD37 TV
Comcast remote won't accept codes for Proscan TV
I had the same problem. I have the 40 inch Proscan and they supplied a remote control guide for comcast. It was only 4 digits and it did not work. I called Comcast and they did not know. I found it needed 5 digits so I added a 1 and it worked The code is 10178. Hope it works for you.
Jul 21, 2009 | Sylvania LC420SS8 LCD TV
Remote not working
If this TV came with an universal remote, try pressing the TV key. Sometimes it works.
If that did not work any other RCA, GE, Proscan universal should work.
Feb 07, 2008 | Proscan 26LA30Q 26 in. LCD Television
Proscan 50" LCD HDTV PLCD5092A - CURTIS INTERNATIONAL LTD Logo
95 people viewed this question
Top Proscan Televison & Video Experts
matt martin
matt martin
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
