Power cycle your home network and perform a connection test on the Wii.
If your Wii was previously connected online, and no changes have been made to your home network, perform the following steps (if you have not previously connected your system online, skip to the next bullet point):
Remove the power from your wireless modem and router. Plug the power back into both devices, starting with the modem.
From the Wii Menu, select "Wii" in the lower-left corner, and then select "Wii Settings." Use the arrow on the right to move to the second page, then select "Internet," followed by "Connection Settings." Last, select your connection file, and the select "Connection test."
Create a new connection file.
Set up a new connection file making sure the Wii is attempting to connect to the appropriate wireless network and is receiving a strong wireless signal. [How to]
for more help visit CBR Tech Solutions
Go to internet options on your Wii settings, select internet, and then connection settings. Once that is done you will be able to see the wifi connection. Click the wifi connection and delete it. Try to reconnect the Wii to your wifi router and you should have success connecting to the internet. If it doesn't connect repeat the steps listed above.
SOURCE: error code 109144 when try to connect to internet via wii console
Error Code: 109144
There was a problem registering the console to the WiiConnect24 service. What to do:
SOURCE: wii Internet connection
When you are not able to connect with Internet from Your Wii, means there is something wrong with the settings. You may go to Wii Fix Guide
and check out the guide available there, This DIY guide will show step
by step pictures to fix the problems yourself without any technical
knowledge.
SOURCE: I changed the ssid on my wireless router! I can
Start your wii, go to the bottom of the screen and click on the wii icon.
Than go further in the program to internet conections.
clic on and your wii wil search for a new connection
SOURCE: i am unable to connect my wii consule to the
You can pusch the button also on the router so he can search your wii.
SOURCE: I get error code 51030
Here are some great source where will will get any kinds of Gaming Consoles Solution
» Sony Playstation 3 (PS3) Console
» Microsoft Xbox 360 Console
» Nintendo Wii Console
» Sony PlayStation Portable (PSP) ...
» Nintendo DS Lite Console
» Sony PlayStation 2 (PS2) Console
a
