When I install a disc nothing happens. Then sometimes it will play after a few minutes. I sometimes get a window that says,"program not responding."
Most units are designed to "autoplay" audio CDs when they are inserted. When they fail to do so, it could be because the CD is dirty or scratched and was bot recognized, the media player that you are using to play the CD was not in a state that it could autoplay the CD, or there could be a problem with the Disk drive or PC itself. Whenever a CD fails to play upon insertion, go to the "My Computer" icon (win7 or below) and see if the CD/DVD drive shows a disk inserted. If so, clicking on the drive will often start the playback.
SOURCE: LAPTOP DVD DRIVE WONT PLAY DVDS
i have just recently updated windows and its took my drive out again, comes up with Windows cannot load the device driver for this hardware because a previous instance of the device driver is still in memory. (Code 38)
Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available.
HELP
SOURCE: Windows boot manager problem acer aspire 5920
Creating recovery discs After setting up the computer for the first time, be sure to create a set of recovery discs of the full factory image. the recovery discs are used to start up (boot) the computer and recover the operating system and software to factory settings in case of system instability or failure.
SOURCE: My dvd rw drive doesn't work anymore!
I'm afraid the drive itself has gone bad. The "working properly" you get in the device manager is a misnomer...all it means is that the device can be seen by windows it doesn't actually indicate the functionality of the device. It is likely that the laser died in the middle of the movie and the only way to fix it is to replace the drive.
SOURCE: acer aspire 6935g wont play blu-ray discs, will
You need to download K Lite Codec Pack (Its Free) and you can install it via....... or you can try googling it.
http://www.codecguide.com/download_kl.htm
It contains all the different audio and video codecs. Your computer might not play it because it doesnt have a blue ray codec by default
Please post your feedback and Vote if the problem resolved as per your satisfaction.
SOURCE: acer aspire one -- windows failed to start. it
Hi ljcoppes...
If you have to use the CD/DVD's for recovery then you will have to buy or borrow a usb connected CD/DVD reader/player.
Using Acer eRecovery by following these steps:
1.Click Start, and then All Programs
2.Click Acer, and then Acer eRecovery Management
3.You may be prompted to enter or create a password. This password will be required to use eRecovery in the future.
4.In the next window on the left toolbar, select Restore.
5.Choose Reinstall Drivers or Applications
6.Choose Contents
7.Choose the driver or application you wish to install
8.On the right, click the Install link and follow the prompts.
9.The computer may restart when installation is complete. If it does not restart, manually shutdown and restart the computer.
Note: For older Acer products, the Acer eRecovery Management program may not be available.
If you do not have a set of Acer Recovery Media, they may be purchased from our Acer Recovery Media Order Form.
Please take time to rate me thumbs up
