Question about Smith Watches
Remove fireing pin for smith & wesson5906 - Smith Watches
Posted by kenneth ray on
protector606
    Champion:
  • 203 Answers
How do I replace the battery in smith & Wesson hf-16
Remove the back panel to gain access to innards. Remove battery and replace. Replace panel.
Sep 20, 2015 | Smith & Wesson Watches
Smith wesson repair
What have you been shooting ???? My advice is strip it & examine closely for other damage & take good close up pics from all angles & contact the maker....this is a serious problem not to be entrusted to your average local gunsmith............jimbanjo
Apr 10, 2014 | Smith & Wesson Watches
Smith wesson problems MP15/223 cal.
How many rounds are you capping off on one trip to to the range? If it a 100 rounds or more, your weapon will retain a small amount more burnt powder and the lacquer coating on the cartridges, but it really is hardly noticeable, but still need to keep your weapon clean no matter if you are using copper. Made in USA. The mp (military /police) is a cheap version of that rifle with no cover over the breech, and no clambering damper. Still worth 5-6 hundred new.. The firing pin cruds up, and if it was fired before you got it and wasn't cleaned that would do it. If it fires, it will jam! Try the dirty gun stenerio, not a bad choice, Colt or Armalite get a little more respect and higher price. Never give up on a 15 , parts are available and reasonable price, and ther are a million upgrades , but careful not to find that you have made it too heavy
Apr 20, 2017 | Watches
Shell does not eject slide jams..I pull clip, pull slide back a couple times , shell ejects what is my problem
Hi! Kevin.....bit hard to know !....assuming ammo is correct dimensionally & of good power., & extractor & ejector are in order & chamber is good & slide is free & full sliding......then my first guess would be sticky firing pin not retracting properly thus stymying ejector action.......any stickier & you might get full auto ?......are you puncturing primers ?.. if gas back escape is part of the picture , bullet may not leave barrel . I suggest you do full strip , incl firing pin , clean & remove any burrs ..... worthwhile to run some dummies by hand & see how they behave..........jimbanjo
Jan 16, 2014 | Smith & Wesson SWW-357-R
My wife gave me a smith & wesson watch for christmas. Last week it just stopped working. There is no model name or number on the watch and I know nothing other than that she bought the watch from a...
You need to go to S&W website to determine what kind of warranty you might have. There should be a link to register their products if sold with their name.
Jan 22, 2011 | Smith & Wesson Watches
My watch has lost the tritium plug at zero on the bezel. how can i get a replacement? thank you
This is a dialog I had with a dealer:
Ann: How can I help?
you: I was wondering where would one go for watch parts for the sw tritium watches?
Ann: Smith & Wesson watches, Correct
you: yes
Ann: Here is the contact information for them
Ann: SMITH & WESSON
Ann: CAMPCO
Ann: 4625 W. JEFFERSON Blvd.
Ann: LOS ANGELES, CA 90016
Ann: www.smith-wesson.com
Ann: 888.922.6726
you: thank you
good luck and don't forget to vote!!!
Sep 28, 2010 | Smith & Wesson H3 Tritium Watch Yellow
HOW IS A STAUER NOTCHED LEATHER WATCHBAND REMOVED
These sound like standard spring loaded pins.
To remove them I use a small screw driver and press it gently against one end of the pin, while pushing it lengthwise.
This compresses the spring and allows the pin to pop out.
(take care where you do this as it may fire out and get lost).
It may take several attempts to get pins out, as you have to experiment with the forces applied to get the right balance.
Putting the pins back in is also a skill. putting the pin into the strap, put one end into it receiving hole and press the other end as far as you can. Move the end in line with the other receiving hole and remove screw driver. It sounds easy but takes a little practice!
Jan 05, 2010 | Watches
Hi folks i have 2stanles steel 4"357 and they both miss i of the
You submitted your questin into the wron topic (watches).
Resubmit into the appropriate one.
Dec 21, 2008 | Smith and Wesson Security Products Smith &...
Watches Logo
179 people viewed this question
Top Smith Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Smith Watch Expert? Answer questions, earn points and help others
