Question about Samsung Video Cameras
Camera is dead except for the multi indicator light flashing red then green. Battery fully charged and camera at ambient temperature
The condition you described is usually a problem with power to the circuit board in Samsung cameras. I know you mentioned the battery but try the following:
1. Ensure battery is good
2. Remove the battery from the camera.
3. Let the camera sit with the battery removed
for approximately 60 minutes.
4. Clean your battery contacts on the battery and in the camera with a clean cloth, or Q-tip dampened with alcohol or contact cleaner.
5. Reinstall the battery and try to power on the camera. If your camera still doesn't work it will need to go in for service.
Posted on Jan 06, 2015
SOURCE: Battery Dont Charge
jpierre's solution (in another thread) was right on the money. Touch
the positive (+)end of the 9v battery to the positive (+) end of the
camera battery.Leave them touching for a few seconds (10 seconds should
be more thansufficient). Seems these lithium-ion batteries are subject
to a'digital memory.' Subjecting it to a volt surge almost three
timeshigher seems to clear it.
http://www.batteryuniversity.com/parttwo-34.htm
In short, it works like a charm.
Posted on Oct 01, 2008
SOURCE: I have a samsung L200
You may have to replace the rechargeable lithium ion battery. (Even rechargeable batteries have a life-span :)
Posted on Dec 03, 2008
SOURCE: Battery will not charge
I found this while searching to find an answer to solve my problem. It worked! Some say that it took them about 20 times... it took me about 7. Be patient and just keep trying! Hope this helps!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Posted on Aug 05, 2009
SOURCE: My Casio Exilim EX-S880 wont turn on. Battery is
I found this while trying to solve my exact same problem.. It worked for me after about 7 times. Some other people on the site said it worked for them after 20 times. Good luck!
ylu1 writes:
what i did was...
hope this helps.
SOURCE: I cannot charge my Samsung L210 digital camera
it has a technical problem you should go to a person who repairs
Posted on Aug 23, 2009
