My delonghi coffee machine needs a general servicing. I need to know if there is some place in Saskatchewan that can do this.
Need Service or Repair
See what I found it is a world map and you can find your home country and your home. Hope it works well, kolbrun
SOURCE: need to replace steam valve on delonghi magnifica coffee machine
the steam valve will pop off it comes straight out
SOURCE: Coffee machine Delonghi Magnifica grinding function not working
There are two reasons for this usually. Either the grinder is jammed or the grinding wheel or wheels have broken. Your machine needs to go to a repair shop to be looked at.
SOURCE: DeLonghi Esclusivo Magnifica ESAM3300 Espresso
Hello, you can buy descaling tablets at your local Starbucks. There is also a liquid descaling solution (small bottles) you can buy anywhere.
At the moment I'm using Jura brand descaling tablets I purchased at Starbucks. For instructions on how to descale (quite simple really), see here on p-17 at:
http://www.starbucksstore.com/images/products/pdf/DeLonghi_Magnifica.pdf
Hope this helps.
SOURCE: descaling a delonghi magnifica ESAm04
I had this problem too. The instruction manual says to turn the steam knob only half way counter-clockwise after pressing the button for 5 seconds, but you need to turn it ALL the way to have the procedure start (at least, that was the solution with my machine). Good luck!
SOURCE: Hi. I have a Delonghi Magnifica EAM3400 that wont
poke something up the outlet hole .....pin or something .. or if this dont work u need service and replacement parts .. bsc appliance 07779933829 we carry out repair service via post anywere.
