Question about Sony Televison & Video
Klv32s310A sony bravia gets start on with green light and after a second turns to stand by mode blinking the red light 6 times after each 2 second interval
Starts on and afer a second goes to stand by mode blinking 6 times after each 2 second interval
Posted by hem sagar bajagai on
Anonymous
    New Friend:
Hello Sagar,
green led means tv powered on and status ok.
Red blinking light almost always means defect, overcurrent or overload.
6 blinks for Sony lcd flat tv means trouble in backlight circuit, or backlight inverter (backlight illumination or lighting makes your tv screen visible).
common problems in the inverter circuit, which drives the backlight, or shorted drivers, or short-circuit transformers or open circuits.
You should find the problem in the inverter circuit, or in the power supply board or in the main board.
Also look for bad capacitors (electrolytic caps) which are bulged and swollen on top.
Decoupling plugs from printed circuit boards can help you in finding the problem board by elimination method.
If you power up the set after unplugging certain plugs on f.e. the inverter board , this could result in getting a green power led and concluding that this board is faulty.
succes,
Walter from Antwerp, Belgium.
Posted on Dec 30, 2014
5 Related Answers
Anonymous
  • 320 Answers
SOURCE: Flashing Standby Light (6 times every 2 second interval)
A 6 flash error indicates a problem with the backlight. Your set is less than a year old and still in warranty, so you should contact Sony and arrange for a service call to get it repaired.
Posted on Nov 10, 2008
Anonymous
  • 1077 Answers
SOURCE: my sony bravia tv is flashing red stand by light
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 29, 2009
Anonymous
  • 3 Answers
SOURCE: TV Goes to Stand-by mode
I don't have a solution, but I have the exact same problem
Posted on Sep 08, 2009
Anonymous
SOURCE: 40'' Sony Bravia goes into standby with the light blinking 9 times
I finally managed to solve this problem by unplugging everything - scarts - HDD cables - power etc and left it for an hour. When I turned it back on again the problem had sorted itself out.
Posted on Oct 01, 2009
Anonymous
SOURCE: the picture comes for 2
the picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
Posted on Feb 26, 2011
Sony bravia KDL46-V3000 inch led Tv red light blinks 6 times???
It means you do have a LCD panel back lights problem, in most of the case, a defective back lights inverter could be the cause.
Jun 28, 2017 | Sony Televison & Video
Sony bravia kdl-32bx300 wont turn on
https://community.sony.com/t5/Television-General/Red-light-blinks-6-times-tv-won-t-come-on/td-p/47107
Mar 14, 2016 | Televison & Video
Green power light comes on then 20 seconds later the red stand by light flashes 6 times & keeps trying to turn on, can hear it clicking but nothing comes on screen only red light flashing. can prob fix...
These flashes are called blinking codes, and are fault indications. If you wish to get more details to these blinking codes, check the site linked here. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 02, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony bravia won't stay on 52w4100, clicks with green light three thimes then shuts off and blinks red 6 times
Sounds like a power board reset switch gone bad. Have the power board replaced.
Good Luck Ed Pinero
Feb 03, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I have a Sony Bravia KDF-50E2010 and after changing the lamp the TV stopped working. As i turn the power on the green light comes up for 2 or 3 seconds and changes to the stand by red light. Flashes t
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://electronicshelponline.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Feb 02, 2018 | Televison & Video
The picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
Nov 19, 2010 | Televison & Video
Sony Bravia stuck in stand by mode
What is wrong when it is in Stand by mode blinking red light 4 times, then pause, then 4 times....
Jul 03, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Mar 05, 2009 | Sony BRAVIA KDL-46W3000 Television
Televison & Video Logo
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Demonic-2011
Demonic-2011
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
