Whenever I experience data error with my photocopier machine, this is what I do.
1. unscrew the machine from the back panel removing all the plastic casing.
2. Get a blower and a dusting brush and clean all the dust particles and tonner that has fallen on the circuit board.
3. brush off the dust particles from the sensors and use a blower to blow off the dust.
4. Perform an indepth cleaning.
5. Re-assemble all the parts that was taken off.
6. Power on the machine. I hope this will work.
<li>Unplug
any cables or power cords from the electronic equipment before working
on them. Remove any component cables leading to other devices.<br />
</li>
<li>
Wipe
down the electronic equipment with a soft damp cloth starting at the
top of the device and working downwards. Wipe away any accumulated
dust, lint or dander.<br />
</li>
<li>
Use
a small amount of isopropyl alcohol on a soft cloth to remove
fingerprints from any CDs or DVDs. Work from the center of the media
outwards. Do not rub too hard or in a circular motion.<br />
</li>
<li>
Clean a LCD television or <a href="http://www.ehow.com/computers/">computer</a>
monitor screen by wiping a damp cloth gently across the screen once all
power is disconnected. Wipe down the ventilation area to remove any
dust. Clean the base with the same cloth.<br />
</li>
<li>
5
Open
a computer case by removing the screws that hold the side in place.
Blow dust and debris from the interior with a can of compressed air.
Start at the power supply and blow through the rear ventilation fan.
Continue to dust the motherboard, component slots and case.<br />
</li>
<li>
6
Insert
a compact disc cleaning disc into CD and DVD players to better clean up
these electronic devices from the inside. This cleans the interior
lenses, removing dust accumulation that can lead to early device
failure.<br />
</li>
<li>
7
Rub
down an MP3 player with a soft cloth and a small amount of ammonia-free
glass cleaner. Use a cotton swab to get into crevices and hard to reach
areas that trap debris.<br /></li>
If what you experiencing that the printer attempts feed paper but fails, then try this:-
This is sort of scenario is usually caused by dust inside
the printer. Dust has a way of preventing the sensors from detecting paper.
Also it prevents the rollers from having a firm grip on the paper while picking
paper. I will suggest you get a long handle brush and try to reach as far
inside the printer as possible and brush (from the back and front). If you have
a blower you may also use it to blow well into the interior of the printer (If you do not have a blower the brushing
will still do if you do it well.) This, if properly done should do it. Brush
especially the rollers etc.
This is sort of scenario is usually caused by dust inside the printer. Dust has a way of preventing the sensors from detecting paper. Also it prevents the rollers from having a firm grip on the paper while picking paper. I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). If you have a blower you may also use it to blow well into the interior of the printer (If you do not have a blower the brushing will still do if you do it well.) This, if properly done should do it. Brush especially the rollers etc.
Pull out the paper tray, at the front of the tray, there's a translucent roller in the middle. Remove the roller and clean out any waste paper dust inside & wipe clean the roller before putting it back.
This is sort of scenario is usually caused by dust inside the printer. Dust has a way of preventing the sensors from detecting paper. Also it prevents the rollers from having a firm grip on the paper while picking paper; they just contiue to roll. I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). After blowing, if you have a blower you may also use it to blow well into the interior of the printer (If you do not have a blower the brushing will still do if you do it well.) This, if properly done should do it. Brush especially the rollers etc.
This is sort of scenario is usually caused by dust inside the printer. Dust has a way of preventing the sensors from detecting paper. Also it prevents the rollers from having a firm grip on the paper while picking paper. I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). After blowing, if you have a blower you may also use it to blow well into the interior of the printer (If you do not have a blower the brushing will still do if you do it well.) This, if properly done should do it. Brush especially the rollers etc.
