Solutions for Fault Code 116-365: Fatal Error of the SPL (Spooler / Spool Queue) is Displayed With a Power the Machine Off and On Message:
> Power OFF the Printer, Wait 45 Seconds, Then Power ON
For more details of the problem, visit:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=397,E=0000000001527486692,K=5902,Sxi=6,Case=obj%2845960%29
Hope this solves your problem,
Thanks.
Fault code 116-365
4 and stop and power save button .
HDD format. ok Ready
Check the error code once more as i dont see that in the list.
http://apps.carleton.edu/campus/its/assets/FaultCodes.pdf
Thanks
Kevin
SOURCE: error 116-365 on dc 3535
That is a hard drive error.
There is a job stuck on it.
Hold 4 + stop + powersave as you turn on the machine.
That will cause the Hard drive to initialize and should clear the job.
I have seen that caused by someone doing an internet print job.
You may want to unplug the printer cable and see if an incoming job is corrupting the network. I have even seen networks be hacked and the machines affected.
If that doesn't reset it. Check the connections to the hard drive.
When you do the hard drive initialization. Hold the 4 , the stop, and power save as you power it on , hold the buttons until you see the progress bar appears on the screen, then release the keys.
SOURCE: xerox DC 3535 error 116-332
Simultaneously press and hold the 1,the Stop
and the Power Save buttons on the Control
Panel,if problem continues repeat the same
with
6,the Stop and the Power Save buttons
4,the Stop and the Power Save buttons
3,the Stop and the Power Save buttons
SOURCE: I have an error DC 3535, the code 116-201
it is error of Hard disk booting
Run the HD Diag
or install it from opertor
of course its a docucolor 3535 not a workcentre 7132
