Question about Apple iPad mini 7.9" 16 GB Wi-Fi 4G White Tablet - Sprint 2012 Model iOS 6, LCD Touchscreen, 1024x768, 10 Hours, Lightning Connector
Certain apps that need wifi don't work even though I have perfect wifi signal. I've already restarted my iPad mini, charged it, and turned on and of the wifi a few times, but that didn't help
I've already charged, restarted, turned wifi off then on again, closed the apps, deleted some things to free up storage, sat right next to the wifi signal box thing, ect.
Posted by Millie Lund on
RayMann
    New Friend:
  • 18 Answers
Possibly one app is locking up networking... My gf had this problem after ios update to 8.0. It turned out facebook app became messed up. I uninstalked facebook and everything was great. Reinstalled facebook and it worked fine after that...In fact her whole ipad got faster... IOS updates are becoming painful...
Posted on Dec 30, 2014
How to connect to internet doesnt recognize router password
Are you sure of Wifi password is correct?
if so, 1st; try restarting your ipad by holding down power/sleep button untill it show "Slide to shut down" leave it off for 10 seconds & then re-open it.enter the Wifi -password, sometimes this step works.
2nd solution ; try resetting your iPad network settings, it will not affect your ipad in any thing except it will forget all entered passwords for any wifi you have already connected before. go to General from Setting, choose resett, and inside only reset network setting, shut down ipad & try to connect to the wifi again. Hope this solution work for you. Also you may try shutting down & opening your router again after 10 seconds while off. Good Luck.
May 19, 2016 | Apple iPad Mini
My Netflix is not loading my films/programs onto my iPad2, but it is perfectly fine on my iPad mini, what's happening? Can you help?
Hi
I have a similar challenge. Netflix works fine on my iPad mini and Samsung smart TV. The trouble is on the Apple TV .
I think I restarted the Apple TV to set this right.
Try going to settings -general -reset on the iPad 2 and see if there is a possibility there.
kolbrun
Mar 14, 2015 | iPad mini Tablets & eReaders
Why cant i access the internet even though i have an internet connection?
Sometimes the wifi connections get messed up. Try quitting all apps, turn the iPad off and restart it. You may want to do this with the units connected to the internet cable as well. You may have to delete the connection and reconnect from your iPad, too. Good luck...
Aug 18, 2014 | Apple iPad (16 GB) WiFi Tablet PC
How do I get my apps from my iPhone & iPad to my iPad mini
If you want to sync new apps to iPhone and iPad, you can take advantage of the "Automatic Downloads" function of iTunes. You only need to tap Settings > iTunes & App Store, and locate AUTOMATIC DOWNLOADS, then turn on Apps and Updates. Finish the steps on your iPhone and iPad so that you can get apps on the other devices when you finish a download on one device. You can also take advantage of the third-party iPhone transfer software, Leawo iTransfer, to sync iPhone apps to iPad. The software can transfer files among iOS devices, iTunes and PCs, and it transfers app data when users want to transfer apps. The following guidance will show you how to sync iPhone apps to iPad, and you can download this software and have a try. Download Leawo iTransfer ' Leawo iTransfer for Mac and install it.
Step 1. Run Leawo iTransfer and connect both device to computer with USB cable. Then your devices will be shown on the main interface of the software.
Step 2. Click your iPhone and choose Apps in the left sidebar. The contents will show up in the right part.
Step 3. Select the apps you want to transfer, and click the transfer button at the right bottom.
Step 4. Check Transfer to List and choose iPad as the target. Then click Transfer Now. Then the iPhone apps you selected will be transferred to iPad in several minutes.
select-apps-to-transfer-from-iphone-to-ipad-l4dxfq00cssffurya0z2o1pk-3-0_0.png For more detail, check: How to Sync iPhone Apps to iPad
Jan 12, 2013 | Tablets & eReaders
You tube won't play
I assume you've already tried restarting the iPad. My next suggestion would be to delete the application and re-download it. This is assuming you are viewing from an application and not from the browser.
Oct 21, 2012 | Apple iPad 64 GB WiFi
My ipad wont charge , icon shows it's charging but it not ?
To get Ipad to show as charging download Asus AiCharger from web and restart computer after install.Plug in usb from Ipad and should now show charging http://event.asus.com/mb/2010/ai_charger/
Oct 12, 2012 | Apple iPad (16 GB) WiFi Tablet PC
How do I unlock a locked up ipad?
If you've got a locked up iPad app or otherwise misbehaving iPad, and want to reboot / reset your iPad, simply hold the sleep and home buttons together until the iPad restarts.
You'll see the shutoff slider come up first, but just keep holding. The screen will go blank and the Apple logo will reappear as the iPad reboots.
Note: this does not reset any data on your iPad. This is just a restart, equivalent to rebooting your computer.
Aug 18, 2012 | Apple iPad 64 GB 3G Tablet PC
IPad shuts down itself
It seems that you've already tried reset (holding the home and power buttons, right?) the iPad and it does not work.
So you may need to connect your iPad to your computer and do a factory restore using iTunes.
Check this: http://support.apple.com/kb/HT1414
Jul 18, 2012 | Apple iPad 32 GB WiFi Tablet PC
How do I make the new iPad's battery recharge faster?
There are many things you might be doing wrong but slow battery charge is a problem with the new iPad. The battery is actually a lot bigger than the iPad 2 which means it is going to take you much longer to charge.
Use the provided charger and don't charge from your computer. It is almost twice as slow to do it plugged into a computer. Charge it at night to give it the most time to charge as possible. I usually turn it off so programs don't run and slow down the charging speed. Every little bit helps.
I can help you with other things too if you ask.
Mar 27, 2012 | Apple iPad HD
How do I charge the iPad battery.
USB hubs typically don't generate the 10 watts necessary to charge an iPad when it's connected to your computer. This basically means you can't use your laptop to recharge your iPad.
Apple recommends finding an AC outlet and using 10-watt power adapter that came with your iPad.
Jan 08, 2012 | Apple iPad2 WiFi 64GB
Apple iPad mini 7.9" 16 GB Wi-Fi 4G White Tablet - Sprint 2012 Model iOS 6, LCD Touchscreen, 1024x768, 10 Hours, Lightning Connector Logo
118 people viewed this question
Top Apple Tablets & eReaders Experts
 Larry
Larry
john smith
gaucherre
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
