Question about Onkyo TX-DS575 Receiver
I have connect my Samsung TV to an Onkyo receiver. TX - DS575. The sound cuts out briefly when goes from live TV to commercial
I took the optical cable direct from TV to the direct TV box... still did it , only on certain channels but only to and from commercials.
6ya staff
SOURCE:
simplemitch
Mitch
  • 752 Answers
SOURCE: Need fiber optic input jack for Onkyo TX-DS575
Had it ever worked, or are you setting it up for the first time?
Have you ASSIGNED the digital input in the menu?
Posted on Dec 18, 2007
Anonymous
SOURCE: Onkyo TX-SR304S 5.1- Popping Issue
I called Onkyo support regarding the issue with the clicking/popping noise and they said that that's normal when you change channels that are digital. They don't seem to think that it's a defect.
Posted on Jan 10, 2008
Anonymous
  • 624 Answers
SOURCE: I hooked up a fiber
Make sure that the place it is plugged into the TV is an output and not an input for the fiber optic cable, and the place it is plugged into the Onkyo is an input and an output for the fiber optic cable. This can be connected backwards very easy. Then you want to make sure that the Onkyo is properly set on the right function to listen to the TV. Check your owners manual on how to set up the optical input and have it assigned to the function you are trying to use. Sometimes these type of receivers have an input mode button that you can set to "optical" or "analog" or "digital" or "auto". Try changing those settings after you make sure the TV optical is an "OUTPUT" and the optical on the Onkyo is a "INPUT".
After you have these thing set right you should be able to listen to it like this.
I hope this helps, if you need more help just reply back on this post, but please give more detail about the connectors and on the TV and the Onkyo, and about the digital input settings on the Onkyo. It would also help to know the model numbers of both the TV and the receiver. There is no way to check out what each of your devices are capable of doing without knowing the model numbers to look up the specs.
Thanks,
Dave
Posted on Sep 07, 2008
Anonymous
  • 151 Answers
SOURCE: Echo when connecting Samsung Plasma to Onkyo TX-SR602
Make sure you have the tv volume turned right down as this will cause an echo,also set amp to prologic 2, and set up xover to suit your speakers or go for the THX standard of 80 hrtz and as a rule of thumb set front L,C,R speakers to zero rears to about +4or5 and your sub to -5[ dont know which speakers you have but try setting the subs on board volume to the 10,o,cloak position],also make sure the speakers -,+ are wired the same at the amp and speakers.
Hope this helps.
CABLE GUY.
Posted on Jan 06, 2009
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: I have an audio problem with my TX-SR502.
If your remote also controls the Cable Box you might want to look at its audio settings. Maybe you muted it.
BTW: it would be a good idea to also run video and analog audio from the cable box directly to the TV if it has speakers so you can watch and listen independent of the Onkyo.
Posted on Mar 11, 2010
I'm trying to connect my old onkyo tx-sr502 receiver to my panasonic smart tv and my xbox 360 to get surround sound. Any help would be appreciated
Hello, Since the TX-SR502 does not have HDMI inputs you need to connect the HDMI from the XBox 360 to the TV. You can connect an optical cable from the XBox to the receiver if the XBox has an optical output. If not you can connect the optical out from the TV to the receiver. Connect to the optical #2 port on the receiver and press the video 2 button. You should have audio. Thank you, Onkyo USA
Apr 26, 2017 | Onkyo Audio Players & Recorders
Hookup Audio to new Samsung 52"1080 TV LN52A650
The best way is to check the user manual. If you dont have i can provide one.
Sep 02, 2008 | Onkyo TX-DS575 Receiver
How do connect surround sound receiver to my tv
use the optical port (toslink cable needed)little square with flap will be lit red or use rca cables red and white audio out fron tv to any port on reciver(aux,cd,dvd,ect) the reciver will have to be turned to this for the surrond to be heard
Sep 06, 2014 | Onkyo TX-DS575 Receiver
No optical audio sound
BECKER Q01
TRUKLINE CD65
model no BE6054
serial no 38001556
*6054AA038001556*
pincode missing
Jul 07, 2012 | Onkyo TX-DS575 Receiver
How do I connect my Samsung Model un46b8000xf led to onkyo receiv
Use the TOSLINK - the optical/digital connector on both devices.
Jul 07, 2010 | Onkyo TX-8511 Receiver
PCM vs Dolby Digital
OK, I just figured this out. Go to the audio options in your DVD player and switch from pcm to bitstream. Now my movies sound right again.
Nov 16, 2008 | Onkyo TX-DS575 Receiver
Will not power up but stand by light is powerd up
I have onkyo tx-ds575 and i need to conect it to my tv and have audio from a LCD flat panel.
Oct 05, 2008 | Onkyo TX-DS575 Receiver
Onkyo ts595 goes into protect mode with volume increase
Hold the VCR/DVR button in and press the ON/OFF Standby button. The display should briefly read CLEAR and then the unit switches off. If that clears protect mode, you'll need to redo the Audyssey and configuration setup as these will have been cleared by the reset.
Sep 27, 2017 | Onkyo TX-DS575 Receiver
Dec 18, 2007 | Onkyo TX-DS575 Receiver
Audio connections between Onkyo TX-DS575 and Sony DVD DVP-NS77H
If you are using digital optical or digital coaial and getting sound on regular 5.1 dvd's your conections are fine. With sony players you have to get into the setup menu and turn DTS "ON" in the audio sub-menu. For some reason they default it to "off".
Dec 17, 2007 | Onkyo TX-DS575 Receiver
Onkyo TX-DS575 Receiver Logo
188 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
