Question about Lexicon I ONIX U82S 8x2 USB 2.0 DESKTOP RECORDING STUDIO
What am I doing wrong? I bought the Lexicon MX200, connected it to Roland Quad Capture Interface using SP/DIF cables. I am seeing the MX200 as a plug-in. The problem is, when I click on MX-Edit, I am
Uninstalling and reinstalling,switched wires.
Posted by Grantis Cudjoe on
Matthew Spark
    Genius:
  • 1,066 Answers
You have to set a master and slave(s) devices, and ensure that all the timings (16/24 bit, the 44.1/44/96k) are consistent in all devices
Posted on Jan 03, 2015
Reverb only in one speaker
Have you checked the cables, jacks, pan settings etc?
There may also be damage to the potentiometer.
Mar 22, 2015 | Lexicon MX200 effects unit (with )
Lexicon mx 200 preset knob frozen
If unt was dropped, look for broken PC board in the vicinity of the rotary encoder. Also look at solder connections to make sure they are sound. A little contact cleaner applied to encoder through an opening so the spray gets inside will help clean contacts. If the knob itself is hard to turn, the shaft is likely bent, and there may be damage to the encoder itself.
Oct 27, 2012 | Lexicon Mx200 Reverb Delay 1u Effects...
There is a high frequency noise in my sessions. I am using a Lexicon Alpha interface with Cubase 5 but now I can't record because of the noise. How can I solve this problem?
Make sure you are using BALANCED cables either XLR or TRS. Make sure ALL interconnected equipment is powered from the same receptacle. Make sure the level to the Lexicon is line level as using excessive gain at its input will admit noise.
Jul 28, 2011 | Lexicon Alpha Personal Recording Studio
The unit itself is generating too much noise(hiss). some effects are noisier than others but overall noise level is unacceptable. all the product reviews say how quiet this unit is. tried changing signal...
Check that: You are using BALANCED interconnection lines (TRS or XLR) everywhere. Low quality cables can cause or let in noise and hiss.
Check that ALL, and I mean ALL interconnected equipment is powered from the SAME receptacle or power conditioner.
Check that you are not using a noisy source or recording system like the internal audio of a PC for instance.
Short the inputs to ground and see if the output noise goes away. Some effects are noisy because the inut signal after effects gets added back into the output.
You haven't described your setup and without that information there is not much more I can add. Ferreting out noise is one of my specialties. In general your input level should NOT be too small as this leads to less signal to noise ratio due to digitizing noise. Look at the Lexicon specs to find what the levels should be. Without the description of your setup I can add no more...
Jul 16, 2011 | Lexicon MX200 effects unit (with )
Lexicon MX200 screen coming up as "ER", nothing else happens, and no sound
hello I have the same problem, I'm told that updating the firmware of the Lexicon MX200 is solved but it turns out that my pc does not recognize the device via USB to update, any solution? thank you very much
Jul 06, 2011 | Lexicon Mx200 Reverb Delay 1u Effects...
Hi, I'm not sure of the polarity of the Lexicon mx200. I have bought a multi tip transformer & it gives 2 options of outside + or inside +, do you know which is which please, I don't want to fry it!...
DO NOT use universal adapters to run these devices. Accidents are too easy and often the universal devices do no have adequate filtering. You are off on the wrong foot to start with as this unit does NOT have a polarity since it REQUIRES an AC adpter, not a DC one. What you have WILL NOT WORK. If you have connected it, it should NOT have caused damage, you just won't get any audio out, even if the unit lights up on one polarity. The unit generates both polarities inside using the AC input.
Here is an example of correct adapter: http://lcdpayless.com/productpage.php?productId=5793
Apr 25, 2011 | Lexicon MX200 effects unit (with )
Lexicon alpha does not install with XP SP1a, error = "Cannot start device code (10)" Drivers from disk are installed, device is listed in device manager with a yellow exclamation point. Do i need...
You should be at SP2, but that MAY NOT be the problem. One thing to check is if you are supposed to have the device connected when you install the software... in SOME cases doing it with or without connection will affect the outcome. Also make sure ALL virus/spyware/popup blockers are disabled during install.
Before using this device, make sure that going to the control panel and looking at the "Sounds and Devices" shows that the Lexicon is the inout and output device for all the tabs within that window.
Dec 16, 2010 | Lexicon Alpha Personal Recording Studio
Im having a problem with hearing my b-1 studio condenser mic on the lexicon alpha progam?
Sorry but... Very simply, you CANNOT use a condenser mic with the Alpha since it does not supply the required Phantom power for the mic. You must step up to another interface to use condenser mics. You can use dynamic mics with the Alpha or other audio sources. I use a Roland/Cakewalk UA25E interface with condenser mics and also the Lexicon Omega which does have Phantom power for the mics..
Nov 03, 2010 | Lexicon Alpha Personal Recording Studio
Lexicon alpha interface is recording a faint high pitched sound
Check for ground loops.
You MIGHT be able to cut the noise by setting the EQ's to clip the highs.
Jul 09, 2009 | Lexicon Alpha Personal Recording Studio
Lexicon I ONIX U82S 8x2 USB 2.0 DESKTOP RECORDING STUDIO Logo
Top Lexicon Music Experts
Marvin
Marvin
Are you a Lexicon Music Expert? Answer questions, earn points and help others
