Question about Oregon Scientific Measuring Tools & Sensors
What channel must I have it set on 1 - 2 or 3) ?
I have tried channel 1
Posted by Marvin Tinklenberg on
How to make channel 34-1 show again?
Digital channels come and go. Channel 34-1 may no longer be operational but frequently other channels start up.
Jul 02, 2014 | GE 34760 Passive Flat Panel HDTV Antenna
Does the motorola t4500 have an eliminator
Setting a Channel
Your radio has 22 channels. Channels 1-7 and 15-22 are 1 watt. Channels 8-14 are
0.5 watt. When the radio is on a 1 watt channel, displays. When the radio is on
a 0.5 watt channel, displays.
1. With the radio on, press . The current channel flashes.
2. Press or to set the channel.
3. Press to save the channel setting. You have a pretty straight forward Low wattage FM Walki/Talki
I would have them returned or replaced.
If you can not transmitt on one to the other
Channel
Channel
May 02, 2014 | Motorola Radio Communications
Some dtv channels missing on VIZIO
Have you tried doing the channel search? If that does not help replace the main board
Apr 12, 2014 | Vizio VL370M LCD TV
I have a turntable with a white and a red male RCA output cable. I am trying to hook it up to a Marathon DJ-1000 amp which has two TRS input channels - Channel 1 and Channel 2. Should I buy a twin female...
If I understand you correctly each channel has a single input in the amp, then yes! white goes into channel 1 and the red plug goes to channel 2 this way your signal will be stronger which translates into louder sound.
Jan 25, 2011 | RCA Audio Players & Recorders
PROGRAM AFTER ALL LOCKOUT OF ALL CHANNELS ON A BC60XLT-1 SCANNER
With the channel display showing 000.0000 you may be able to program a new frequency into it, and the new program will release the lockout. Have you tried the normal programming for any channels?
Bill B
Apr 08, 2010 | Uniden BC60XLT-1 Handheld Scanner
Not working
Try to connect your computer hard wired to the router. Check if you could ping the router. If yes, try to access it. For the wireless channel, I suggest you try channel 1, 6, 9 and 11.
Feb 24, 2010 | 2wire (2701HG-B) Wireless Router
I can get channels 1 to 4 can't get channel 5 and no freeview
Hi, I had the same problem, try removing your aerial from the box - retuning and saving so it blanks out all previous channels and then reattaching the aerial and doing another retune, this worked for me. Good luck.....
Oct 06, 2009 | Televison & Video
6 mnths old Alto L8 Mixing desk developed hiss on channel 1 only.
The slider or the amps for channel 1 may have a problem.
Sliders do wear out.
Try shorting channel 1 input and see if that affects the noise. A hissing noise is probably a bad preamp chip. That is shop work at a repair facility.
Aug 16, 2009 | Music
I am trying to set up the "favorite channels" function on my harmony 880 remote and I keep getting an error message that the channel numbers are not valid. On my TV, for example, NBC is 05-1 (that's what I...
I have seen channel designations like this when using a satellite TV provider. From what I know (which is not a lot, I'm afraid) is that some affiliates offer analog and digital and digital sub channels so an example would be:
05 (main analog channel)
05-1 'digital' (depending on the receiver)
05-2 'digital sub channel'
05-3 'digital sub channel'
etc
So, you may want to try just putting in the main channel '05' when using the Logitech software to program your favorites. Below is a link to a good post on the Logitech forum that tells how to program your favorites. Hope this helps!
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9691
Mar 24, 2009 | Logitech Harmony 880 Universal Remote...
Measuring Tools & Sensors Logo
162 people viewed this question
Top Oregon Scientific Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Are you an Oregon Scientific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
