I have an Amana PTAC ac 15000 BTU that has stopped, the power cord keeps tripping. I removed the power cord and plugged it in to the socket and the breaker did not trip, any clues. I'm thinking of just getting a new unit, it is 10 years old and has never been serviced.
I think you've gotton your moneys worth with ten trouble free years. The power cords safety device is a bit more sensitive to a high resistive short to ground than your breaker is. I would suggest that there is exactly that: a high resistive short to ground within the cabinet of the PTAC. It has been years since I have been on a PTAC call and am unable to suggest specifics. But if you are competent and capable of using a DVOM, open up the unit and begin a systematic approach of determining the problem.
The FIRST thing I'd do is check the motor and the compressor with a digital megohmeter. Sometimes their problem will only show up with this sensitive device.
SOURCE: Trips circuit breaker
If the unit is new then the unit may be over-sized for the electrical circuit. If the unit is not new then the compressor may be failing
SOURCE: I have an Amana PBE12 Thru-Wall AC/Heater for my
is the breaker large enough for the unit? this could be the compressor locking up if if it a heat pump style, or sticking thermostat..
SOURCE: amana air conditioner keeps popping its cord breaker
This a ground fault breaker. They do go bad. Is it kicking it all the time or when you plug it in. I replaced a lot of the ground fault plugs. You have to go to the Appliance Parts store to get a new power cord. If you have a problem with thisyour warranty should cover the power cord check your warranty. Rus
SOURCE: I have a amana ptac
The h1 means you have a voltage problem. Check your voltage to the unit.
SOURCE: I have a Amana PTAC
To all friends! Whenever you find breaker tripped or fuse blown, it's an indication some device/s are in problem.
To get tripped breaker:
1. Condenser too dusty- clean it.2. Fan motor or compressor grounded-Replace. 3. Compressor high amps due to capacitor weak-replace capacitor. 4. Burnt wire-rectify. 5.Short circuit-rectify.
