Question about Samsung Radio Communications
Connect sony dr-tn200 bluetooth headset to samsung mx-h620 hifi
I purchased a Samsung mx-h620 HiFi for my son but can not pair with the Sony headset. There is no headphone socket on the unit.
Posted by Angela Boland on
zeceten
    Sergeant:
  • 399 Answers
Bluetooth is a short-range (33 feet/10 meters) wireless technology that allows two Bluetooth-enabled devices to connect wirelessly and communicate between them. If your son's Samsung MX-H620 HIFI is not Bluetooth-enabled, the two devices will not be able to connect in any way. If the headset were corded (it is not because it is Bluetooth) you could plug its cord into the headphone (LINE/AUX IN) jack on the Samsung. if the Samsung system is not Bluetooth, the only option is to find a suitable Bluetooth adapter to make it Bluetooth-enabled. However, you can use the Sony headset to listen to music or make phone calls from Bluetooth-enabled devices that you own such as phone, tablet, iPod, iPad.
Posted on Dec 30, 2014
wwlvictoria
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Samsung Master
  • 1,001 Answers
Bluetooth Headphones V3.0 Handsfree Stereo Wireless Headset with Microphone earbuds for Apple and Samsung LG Amazon com Charm sonic Bluetooth Headphones V3 0 Handsfree Stereo Wireless...
Posted on Dec 31, 2016
Connecting a sony STR-KM7600 to a led tv
If you are using a cable box, then run your HDMI cord into your receiver HDMI input. Then another HDMI cord from thr Reciever HDMI out to your Samsung Hdmi input.
Apr 17, 2012 | Audio Players & Recorders
Hi, I have purchased Samsung Galaxy ACE S5830 whether it is possible to connect Samsung Bluetooth Headset WEP 450. Kindly inform me how to do it.
1 Enter Pairing mode. • Turn off your headset and press and hold the talk button until the blue indicator light remains lit after blinking. • If you turn it on for the first time, it proceeds into Pairing mode immediately.
2 Search for and pair with your phone --> turn on the bluetooth with the widget on the home screen or in the settings. (Bluetooth PIN: 0000, 4 zeros)
• If the pairing is successful, the blue indicator light will flash 10 times rapidly before entering Standby mode. • If the blue indicator light remains lit, retry pairing.
Mar 13, 2011 | Samsung WEP450 Bluetooth Headset - Retail...
What is pin for pairing motorola h620 with iphone
motorola uses two different pin pairing codes, they are as follows 0000,or 1234.i hope this helps
Feb 26, 2011 | Motorola Mobility H620 Bluetooth Headset
Code for sony dr-bt100cx bluetooth
Hi, when you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope that helps...
Thanks for using fixya.
Nov 25, 2010 | Sony DRBT100CX Bluetooth Headset
Sony ericsson bluetooth headset tryin yo connect
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Nov 18, 2009 | Sony Ericsson Mobile Bluetooth Car Kit...
I have a Blackberry Curve 8320. I purchased a Motorola Universal Bluetooth Headset H620 that is supposed to be Blackberry compatable. I am unable to get my phone and bluetooth paired. What do I need to...
It may be the pairing code that you are using. Usually it is 123, 0000, 1111, 1234, or some other variation.
Make sure, also, that you are in pairing mode with the headset. If you can scan via bluetooth and detect the device, then it should be ready to pair.
Nov 02, 2009 | AT&T Blackberry Curve 8300 Smartphone
Connecting bluetooth head set
>Paraphrasing from the manual:
>1. Turn off headset.
>2. Press & hold the Multi-function button for 8 seconds, until >the lower half is lit up blue (not flashing).***THIS IS >IMPORTANT! KEEP HOLDING IT IN UNTIL IT STOPS >FLASHING! The whole thing will be lit up blue, but the lower >half will be brighter.
>3. Set your 'phone to discover bluetooth devices.
>4. Your 'phone will find the "Samsung WEP410" headset, & >ask if you want to pair with it. Confirm by pressing "Yes" or >"OK".
>5. Enter passkey or PIN "0000" (4 zeros), then "Yes" or "OK".
Mar 11, 2009 | Samsung WEP410 Bluetooth Headset Wireless...
I don't have the code for my sony wireless dr-bt22
Trying pairing with a PC. Pairing defect key is 0000. Good luck.
Jan 29, 2009 | Sony Bluetooth Wireless Headset for...
I don't know how to work my Wireless Bluetooth Headphones. Sony(Wireless Stereo Headset DR-BT22)
I went to www.sony.com, clicked on customer support, typed in the model number of my headphones, and then clicked on the "operation" link.
A PDF file came up and told me exactly step by step how to use my headphones.
Jul 26, 2008 | Sony Computers & Internet
Radio Communications Logo
258 people viewed this question
Top Samsung Radio Communications Experts
Anthony Ward
Anthony Ward
Jean Thiebaux
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
