Question about Home
HOW TO I CHANGE F TO C ON A GEON NON-CONTACT FOREHEAD THERMOMETER
Posted by Denis Caddy on
Shira
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 119 Answers
This page has Contact and Customer Support links that may work for your product:
http://www.allproducts.com/PR/full_story_geon.html
Posted on Dec 29, 2014
Testimonial: "Thanks for the effort of replying, but I still could not find the answer on how to change F to C. Cheers, Denis"
  • Shira Dec 29, 2014
    OK - Try this:
    1. Choosing Celsius or Fahrenheit as your Unit of Measure Press trigger to activate unit Select degrees Celsius by pressing the "oC" button, or degrees Fahrenheit by pressing the "oF" button Wait several seconds Press trigger again to confirm selection and exit. (If this does not work it is possible your thermomete does not includde this function.)
2006 chevy implala dashboard reading engine hot ac off. Already replace sensor
Is engine overheating ? Buy a Non-Contact Infrared Digital Thermometer LCD Digital Pyrometer Temperature GM320 11 99 Non Contact Infrared Digital Thermometer LCD Digital Pyrometer... Check temp at upper radiator hose , at 221 degrees the cooling fans should come on ! If the fans come on the sensor isn't the problem isn't the problem . The gauge it self could be bad , or the stepper motor that controls the gauge .c How to repair GM Instrument Cluster Speedometer Gauge Stepper
Feb 04, 2017 | AC Cars & Trucks
My Beechams Digital Forehead Thermometer is continuously beeping?
Remove the battery and count backward ten Mississippis then reinstall. This should reset the thermometer. If the problem persists, try the same thing again this time clacking your heals together while simultaneously whispering to yourself, "There's no remedy like Home Medicine.....there's no remedy like Home Medicine....there's no remedy like Home Medicine"....
If that doesn't do anything more than earn you a smile and a warm pat on the back from your midwife then I'd throw the piece of garbage into the appropriately environmentally recommended disposal receptacle and buy yourself a trusty old school mercury and glass thermometer like your grand mammy used back when the world was a simpler, less technologically overconvenienced place.
ps...I hope whoever is enfermo feels better asap!
Good luck....
Heal them all Jesus!
Feb 15, 2015 | Home
Beechams forehead thermometer instructions
Why not check out a non-contact digital thermometer? I think that would be easy for you to measure someone's temperature.
Catherine J. Davis
Non Contact Digital Thermometer
Aug 28, 2014 | Home
Change temperature setting on Forehead Thermometer
no I contacted customer service, this thermometer reading ONLY in F, there is no option to change it to C
Jan 25, 2014 | Braun Home
HOW TO SELECT CELSIUS IN FHT 1000
Contacted customer service, the FHT 1000 forehead thermometer reading ONLY in F, there is no option to change it to C
Dec 09, 2013 | Braun Home
Forehead thermometer
hold down the button the top until it beeps then push the top button on the reverse side
Oct 27, 2013 | Braun Home
Forehead thermometer fht1000
hola, quisiera saber como le puedo cambiar a mi termometro para q mida en celsius, es el termometro forehead de braun FHT1000 gracias
Sep 29, 2013 | Braun Home
1998 Pontiac Sunfire Symptoms: -Overheating
What are you going by to say it's overheating , temp gauge ? Have you test to see what the actual temp. is > Hook - up a scan tool ,what's the PCM - engine computer seeing for engine temp. ? 223 degress the PCM should turn on the cooling fan . You could buy a Non-Contact Infrared Thermometer With Laser Targeting at harbor freight ! Radiator very hot ????? What is the right temp .
Non Contact Infrared Thermometer With Laser Targeting
Could be a bad temp gauge . Is the coolant surging inside the cooling system ? Does it have a radiator cap ? Have you replaced it ?
May 06, 2017 | 1998 Pontiac Sunfire
Home Logo
996 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
