Lid must be closed for spin to start.
If the lid is closed and still no spin, the sensor (switch) for the lid may be bad. If you can locate it and manually trip the sensor, you may find it out of adjustment. Yours may be on the rear-left of the top of washer.
Replacing the sensor isn't too difficult or costly...but, always-always unplug the power before you work on it.
If you have determined that it is not the sensor, give the timer a little click forward. If that works...the timer may be going bad (not advancing).
Does the spin work in other wash cycles? If so, it might be bad timer.
SOURCE: KENMORE WASHING MACHINE MODEL#110. 254872300 WONT SPIN
if your sure it will agitate?[because the pump is on the other side of the motor and will drain,but if coupler broken ,wont agitate or spin although it makes noise like its working.so if will truely agitate drive coupler fine and its going to be the clutch or that area unless somthing[clothing] is between the two tubs creating anough resistance to stop the tub from taking off.clutch pads will just slip on drive plate.hope that helps>God bless ,tom
SOURCE: Broken Machine-Kenmore 70 series Washing Machine
This is commonly caused by a lid switch malfunction. If your model number is correct, the lid switch for your washer is located under the right hand side of the washer casing along the wash tub rim. The switch is activated by a small plastic piece on the washer lid (called a "lid strike") through a small hole. The switch contacts close when you shut the lid. In many cases, the lid switch either comes loose, or the lid strike breaks off. In both cases, the washer will exhibit the symptoms you describe.
Open and close the washer lid and listen for a distinctive "clicking" sound as the switch contacts close. If you cannot hear the switch, make sure the lid strike is intact and the mounting screws for the lid switch (located around the wash tub opening on the casing) are tight. Sometimes, all it takes is to tighten the lid switch screws to realign it with the lid strike. If the switch is defective, or the strike is missing, parts can be ordered on line at searspartsdirect.com. Just type in your COMPLETE model number, which can be found on a nameplate under the washer lid. The lid switch and lid strike will be listed under the "Top and Cabinet" heading. Other sites that offer competitive pricing are repairclinic.com and appliancepartspros.com. If you require instructions on how to replace the switch, you may use the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
If you have questions, or if the diagnosis is incorrect, please let me know. I hope you find this information helpful.
SOURCE: Kenmore 80 series top load washing machine won't agitate or spin
defective motor coupling,,replace..onthejob
SOURCE: kenmore 80 series washing machine agitator will not rotate
you need to replace the agitator dogs, very simple. Go to www.shop.washermd.com and download the tutorial, thanks
SOURCE: kenmore 80 series washer fills but does not
The agitator dogs may be broken or the transmission could be bad. Try checking the agitator dogs first. They are an easy and inexpensive fix.
