Nikon N55 35mm SLR Camera Logo
Question about Nikon N55 35mm SLR Camera
F--- what does the "F---" mean when it shows up on the top screen?
Posted by smcininch on
Anonymous
    Brigadier General:
  • 3,006 Answers
It means that you haven't turned the lens aperture ring to the minimum (highest number).
Note also that some older Nikon lenses will fit the camera but are incompatible with the F-55 (N55 in USA).
Posted on Jul 14, 2009
3helpful
We have a blue flashing light at the top left hand side what is it for and how do i turn it off
Samsung Galaxy S4: Flashing Blue Light:
Hello. By default it means that you got a text message or some kind of notification. If you are on the home page after opening the lock screen and your text messaging app doesn't show that it received a text message (if it shows it received a message there would be a one next to it, near "Messaging" app)
blue-flashing-light-top-left-hand-side-kyzl0pi20tqzz121bvlihxv0-1-0.jpg Then, with one finger.. touch the screen at the top of the phone and move finger down the screen (while still touching the screen).. you should see the notification area.. under the settings of that area it will show what is alerting you:
notification screen:
blue-flashing-light-top-left-hand-side-kyzl0pi20tqzz121bvlihxv0-1-5.png If you still want to turn this off.. go to:
Settings>Device>Display>uncheck LED indicator:
tipLEDindicator.mp4
How to stop lap top screen from rolling
Do you mean flickering of screen? That means screen will fli ker or shake just le tat from the power on when something is showing in the screen screen wil start to flicker....If that is ur oroblem..then it might be a problem of lcd cable, FL Inverter, ram or LCD itself...if u are a tech then u can do a re assebling of the laptop and if u r not take tat to a laptop repair centre. .cheers...Jerine Kunjachan
Trying to find the meaning of icons at top of screen of the Samsung Stunt cell phone
Follow the below instructions and this will give you your icons meanings. I have included a link where you can download a users manual if needed.
Display Screen Icons
Your Stunt phone can show you definitions of the icons that appear on
the top line of the display.
To access the Icon Glossary:
In Standby mode, select MENU, then select Settings --- Phone
Info--- Icon Glossary. A list shows of the icons that can appear
on the top line of the display.
http://downloadcenter.samsung.com/content/UM/201010/20101013051332765/Cricket_R100_Stunt_Eng_UG.pdf
Mar 10, 2011 • Cell Phones
How can i remove the r sign showing up on the d ioo top screen the letter r is showing up on the top screen on the camera how can it be removed and what does it mean? my friend is on holiday and asked me...
On the top LCD: r(followed by a number) for example:r59 means that the camera eswtimates there can be 59 more pictures taken with that memory card. Will not affect the images.
I have top load washer kenmor model#110-28087700 its showes on the scren (LLF) WHATS THAT MEAN
This means low fill, Try taking your hoses off in the back and clean the screens off. If this does not work you probably need a new inlet valve. Good luck!
Shows paper stuck at screen and doesnt have
Have you tried pulling out the whole imaging unit?
Open the top cover and front cover to remove it.
The top screen of my ds is white.
FYI. the ds, gameboys, etc use INK surprisingly. try refilling cartrigas or it means your screen is going BAD!
1helpful
A white screen that says set top diagnostics is on the screen
Hello pwon28,
This means that your set top box has been put into diagnostic mode and is showing on the TV. Power down your cable/satellite Set Top Box and then power it back on. This should clear up this problem.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
The green light flashes on my Ds Lite, but it simply wont turn on. It always shows a black screen. Please help.
One of your screens have either come loose at their connection or the screen is faulty which means a new screen.
Just hope its the bottom one as the top screen requires some patience to replace.
2helpful
2answers
My LG VU shows a blue screen with error fatal file:dof: UI line: 0
take it to the nearest phone repair shop ask for flashing Phone ROM
Read Only Memory.
Open Questions:
See all Nikon N55 35mm SLR Camera Questions
Top Nikon Photography Experts
Steven Wander
Steven Wander
Marvin
Marvin
Steve
Are you a Nikon Photography Expert? Answer questions, earn points and help others
