Question about Kenmore Coffee Makers & Espresso Machines
I have a Kenmore Brew N Wave #721.63993301 I'm getting a F-1 error when trying to brew coffee. The manual says "failure, call a tech" but I was hoping to fix it myself. Any help?
It won't brew at all. I'm guessing it has to do with the brewing aspect of the machine.
Posted by Daisy on
  • Daisy
    Daisy Dec 30, 2014
    I'm bumping this up since I can't find an answer anywhere. If it's a quick fix, could someone be so kind and leave a message? Thanks.
5 Related Answers
Anonymous
  • 3130 Answers
SOURCE: Coffee does not brew
the heater eleiment is bad or the thermal fuses conncting the elements are blown
Posted on Apr 25, 2006
Anonymous
SOURCE: Leaking cuisinart grind and brew
Our Cuisinart grind and brew was leaving a puddle under it after making a pot of coffee. I called Cuisinart this week and it turns out the handle of the carafe has to be lined up in the middle of the opening for the carafe. It will be under the word Cuisinart, in the middle.
We have now made several pots with NO residual puddle of water or coffee. It also seems to be making the pots quicker.
Before trying this I had run 2 pots of water with 1/2 cup white vinegar in it also. But it still puddled until we lined up the carafe as noted above.
Posted on Jan 16, 2009
cactus bob
BOB BROWER
  • 267 Answers
SOURCE: delay brew will no longer work.
electronics and steam do not mix mr coffee used to put the control boards under the front where it was warm and dry . now there right where the steam can ruin them ... you might try unpluging it and puting it in the sunlight for a day and see if it drys out another thing go to amazon find your model and make a review , this will help others not to make the same mistake you did BTW just so you know , you dont have a real mr coffee , sunbeam bought them a few years back and now its just china junk .... good luck ......please rate this answer if it helped, 3 or 4 stars .and keep me in the paid department . a 1 or 2 will knock me off the air . thanks
Posted on Mar 01, 2009
NORMAN ZINK
  • 85 Answers
SOURCE: cuisinart Coffee on Demand?12-Cup Programmable Coffee
Hello crystalmeikl,
This is a really common problem with the cuisinarts. I am most familiar with the DCC-1200, but you may be able to solve the problem. The may be an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a water filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it or shuts the unit down, but most people don't know about this fix. I hope this is helpful to you, crystalm. Positive feedback is appreciated. Good luck. NormanZ
Posted on Jul 11, 2009
Anonymous
  • 13 Answers
SOURCE: The "Brew Pause" feature doesn't work
It's the spring part on the bottom of that black basket. Now that it's broken there's really no fixing it. The only thing to do is call the manufacturer (800-726-0190) to get a new brew basket. They are open on weekends, so you could call them today and see what they can do (brew baskets are covered under the 3 year warranty, btw). Just have your model and serial number and you can probably have a new one ordered in less than 5 minutes. :)
Posted on Aug 29, 2009
Testimonial: "Very helpful suggestion to call the manufacturer. I was told to try the self-cleaning, as calcium deposits could be the problem. worked like a charm."
Sears Kenmore coffeemaker will not brew
do you have it set on automatic or manual brew
Mar 10, 2015 | Kenmore Coffee Makers & Espresso Machines
How do I set the clock on the kenmore brew wave
To set the clock:
Find the OPTION button, it is the second top button to the left of the green clock display
1 - Press OPTION
2- Press 1 (to set the time)
3- Press the numbers for the current time of day - then press START (ie: 130 for 1:30 )
4- Press 1 for AM / 2 for PM
5- Time is set !
Jul 10, 2014 | Kenmore Brew 'n Wave 63992/63999 Microwave...
I am in need of replacemnt carafe for a Kenmore Wave and Brew microwave/coffee maker seriel #721.63993301
HI. I have located the parts needed. I will place two links for the cover and the actual Carafe, as well, below:
Carafe Cover - 3550W1A231B
Carafe - 383EW5A162C
Please rate and have a great day:)
Aug 19, 2010 | Kenmore Brew 'n Wave 63992/63999 Microwave...
After getting Replace Water Filter VEntilate display I replaced with Saeco Intenza water filter cartridge I have always used. However, unit does not move off this display after I press OK button. I have...
After replacing the filter in the tank, keep the button pressed; when the indicator light is flashing, then release the button.
Also at times, the gears in the brew drive assembly will not complete the cycle to the proper start position for different reasons. Some of the reasons are:
  1. Brew group jammed or blocked.
    Note: A jammed or blocked brew group can happen when the brew group starts the cycle but doesn’t finish it.
  2. Either one of the micro-switches in the brew drive has gone bad.
  3. Brew drive motor failure.
  4. Broken teeth on either of the brew drive gears.
  5. Dirty brew group, covered by coffee grinds.
  6. Brew group or gears not lubricated.
  7. Connections to the board from brew drive assy., or motor have gone bad
Oct 08, 2009 | Saeco Incanto Classic Espresso Machine
My coffee pot on a kenmore brew and wave is missing a stop
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number at the Sears parts site.
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
Jun 27, 2009 | Kenmore Microwave Ovens
Franke Saphire Coffee Machine when turn keeps coming up with Mulf
This is due to the failure of the brew system, 1, an o ring on the brew piston may have failed
2, the brew unit may have failed - Replacement will be required. 3, the brew motor may have failed - replacement will be required , 4, numbers 2 and 3 ...
The brewer and motor are not really serviceable (labour intesive) replacements are more economical. have to hope its just the O ring!!!!
Jun 20, 2009 | Franke Saphira Espresso & Coffee Maker
Coffee carafe
You should be able to find it at the Sears parts site.
Enter the model number from the tag on the unit.
A full Sears/Kenmore model number has 3 digits, a dot, then a few more digits, such as ###.#####
or ###.########, etc.
Jun 14, 2009 | Kenmore Brew 'n Wave 63992/63999 Microwave...
I have a Kenmore Brew Wave that has cracked in the plastic unit that you put the water in to make coffee. Where can I find a replacement. Had a job getting a new carafe when it cracked.
Sears do not make the carafe anymore but this is something that I do that may help?
I took the top off the carafe an just placed it to the top of my coffee cup and sat the top part the holds the coffee on top of it and just poured the hot water from a cup I heated in the microwave. Do it very slowly until you get the it right for you, it works for and I hope it will do the same for you guys ?
Apr 17, 2009 | Kenmore Brew 'n Wave 63992/63999 Microwave...
Coffee Makers & Espresso Machines Logo
62 people viewed this question
Top Kenmore Coffee Makers & Espresso Machines Experts
gbob59
Jude24
ray gallant
Are you a Kenmore Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
