Tried checking to see if there was something stuck on, but couldn't see anything. Not sure if there is something on the sensor. No sure where the sensor is... The only way to stop it from running is to unplug it... Is there a way for me to repair it?
The on off switch is bad. .it controls the power if it will not switch off. Remove the cord from the wall. Then take the top panel cover off then with a small piece of tape mark the bottom wire on the switch .simply pull the top wire off switch. Tape the end of the wire so it doesn't touch anything. Plug back into the wall it will not run. Replacement of the switch is needed. Unplug cord from the wall. Take the wire off bottom of the switch. The switch should have 2 tabs on it squeeze them ad push the switch out . Go to Radio Shack get a new switch.
SOURCE: My shredder keeps running and won't stop in on/auto mode
Does the shredder have the electronic eye to sense paper? Sometimes dust will collect on the sensor causing it to keep running.
SOURCE: Fellowes Shredder keeps running
You should be able to flip up the cd cover and visibly see the sensors in the center of the paper entry(look like little LED lightbulbs) Clean with a Q-tip dipped in rubbing alchohol. This should solve your problem. If it doesn't you probally have a burned out sensor. call 1-800-945-4545 to check with customer service.
SOURCE: Model: SH9210PL
sensor is dirty. clean the sensor. it is located approx. 3 inches from left side of paper slot, 1 inch below top.
Testimonial: "I got this reply long ago & it worked perfectly. I was a new user & obviously did not do every thing necessary to remove it from my question list. "
SOURCE: Paper Shredder blades do not turn, even though motor is running
yes, it's the plastic gear that's shredded in this shredder. the drive gear on the motor is metal, as are the gears attached to blades. between is a single plastic gear which is chewed up the instant resistance is great enough. fabulous engineering. not a difficult fix, but where does one find the replacement part?
SOURCE: Kindly help in repair of my Fellowes FS5 shredder
I have the same problem with this model shredder. I spent 1 hr to open it up, and confirmed the PLASTIC gear that turns the cylinders are destroyed! That is why even the motor runs like crazy, but the cylinder cutters do not move at all. Why the engineer didn't design to put in a metal gear? Is it more durable than a thin plastic gear?
The majority of Fellowes personal shredders (small shredders that can fit under a desk) are repairable and will have parts available. If you would like to check your model shredder to determine if parts are available, please click the "Ask a Question" tab above, and advise the model of shredder, the shredder's serial number and a description of the part needed. The serial number will be located on the bottom side of the shredder head below the bar code.
*** Please note: If your shredder is still within the warranty period, we ask that you do not open your shredder until speaking with a Fellowes Representative, as opening the unit may void your warranty.***
Fellowes office/commercial shredders (large shredders that cannot fit under a desk) are repairable and parts will most likely be available. Please do not try to repair the shredder yourself or you will void your warranty. Models included in the office shredder line are 125i Series, 225i series, 325i series, 380 series, 420 Series, and 480 series.
If you would prefer to have a local servicing dealer provide repair service to your office shredder, and would like to find a dealer in your area, please see the below link to search for a dealer by zip code.
http://www.fellowes.com/Fellowes/site/support/support_authorizeddealers.aspx
To order replacement parts, or if your model shredder is not listed, please click the "Ask a Question" tab above to ask us about your shredder. *** Please be sure to include your serial number from your shredder for the fastest service ***
Our office hours are 7:00 AM to 7:00 PM, Monday through Friday Central Standard time.
I was having the same problem with my shredder. I called
customer service; I was informed it was the gears on the inside of my shredder.
My shredder is no longer under warranty. Don't open your shredder to repair it yourself
because it will void your warranty. However, she is mailing me out the part I
need for a small fee. Their customer service number is 1-800-327-8508 in the
USA and international only 1-310-793-5650. I do hope this help you!
The shredder will work in forward and reverse. When the shredder is on "On/Auto" it won't turn off. All of the documents have been shredded and the machine keeps running.
