Looking in settings and trying different wallpapers, font sizes. I can't find where to change it from everything looking inverted. All photos are negative. Text is reverse.
Device > Display -
Touch this option to change the display settings. On this screen you can set the brightness, change the background wallpaper, set the auto-sleep time or change the default font size. You can also enable connectivity for a wireless display
there is no real change in the font size it comes set hard coded, if you go to credit, then more until you see view parms, enter password, then set parms you will then press the print button and then use prev and next to see if you see a font size, i work in this field and i have never found a terminal that you can change the font on, it usually will only change a little and it does not really make a difference in how it reads and or the paper use.
click start control panel,display,desktop you can select a different desktop from the drop down list or a browse button where you can select different picturesthis may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings always click APPLY after making any changes
on the top of the internet page you should see some tabs file edit view favourites tools and help click on the view tab on the drop down list you should see a zoom size %
click a different percentage also a text size you might try a different text size although this will not increase the size of the page only the text fonts inside it
if you do not see these tabs in the top toolbar
right click in the top toolbar you will see a number of toolbars and options select the menu tab this will add at it to the toolbar
desktop from the drop down list or a browse button where you can select different picturesthis may vary depending on your operating system also settings you can
always click APPLY after making any changes on
% click a different percentage also a text size you might try a different text
size although this will not increase the size of the page only the text inside
it if you do not see these tabs in the top toolbar right click in the top
will add at it to the toolbar hope this helps
hi,
1) CTRL + to increase font size CTRL - to decrease font size CTRL 0 (zero) to set it to the default size as defined in your web browser
2) Set the size again, if necessary, in your browser or Try changing the text size in View\Text size in the Explorer menu.
