Question about Bush DVD142RC 14 in. TV/DVD Combo
Dvd showing bad disc or insert error
Tried cleaning disk - nothing happened. Not too sure what to try next.
Posted by Elaine Lambie on
steve cannon
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 23 Answers
Use a cleaning disc on thed dvd drive in the tv
Posted on Jan 02, 2015
1 Related Answer
Danmart
Daniel Martinez
  • 291 Answers
SOURCE: wrong disc on screen
If you DVD player is damaged, and u have external AUDIO\VIDEO inputs.Buy a $59.00 scan DVD player & save yourself a $100 repair bill.
The DVD heads coud be internittan { sometimes it works & sometimes i don't } U could have issues with the country codes that tell your DVD where the DVD CD was made at or where is was recorded.
Posted on May 12, 2008
Some DVDs will play, others wont
You could try checking the DVD discs in a region free player program to see if the DVD is playable. You could try Leawo Blu-ray Player which can play Blu-ray and DVD discs from any region. If the DVD discs can't be played on this player, then it's highly possible that the DVD disc is unplayable.
Apr 01, 2018 | Sony Audio Players & Recorders
Hi, I have an ASUS M50SV running Vista. I am not sure what happened to it, but absolutely nothing comes up on the screen when I boot up now. There are no beeps, I can hear the vista melody that comes up to...
Try function f4 maybe screen output is being switched to alternate screen only.
try starting vista in safe mode in case a display setting is incorrect and needs checking
http://support.eset.com/kb2268/?locale=en_US
Mar 23, 2017 | Computers & Internet
Cd player doesnt work and states ''error 06''
If you all ready try cleaning the CD lens now the next step is disconnecting the negative wire from the car battery for about 10 min. but make sure that you have the radio code before disconnect the battery or make sure that your radio does not have a security code, if nothing happen after this try you must send the radio for repair usually they have to replace de CD lens. Good luck
Jan 02, 2010 | Car Audio & Video
Shut off and won't come back. It's like it is dead.
you have a problem with the ram or the processor
May 30, 2009 | Acer Extensa 5420-5687 Notebook
CD Drive
your cd drive lens needs to be cleaned by a lens cleaner ...
Jan 10, 2009 | HP Pavilion Slimline S3123W Desktop PC -...
Won't start
It sounds like you have a food blockage or some blockage between where the water fills up and where it goes into the pump you need to take out the water wand (the rotating thing with water coming out) only the bottom one. You need to unscrew the water wand and make sure nothing is blocking in there.
If not then check your filter which should be next to the water wand remove it and then clean it and make sure nothing in in there to block water getting through.
If you have any questions please dont hesitate to ask
May 27, 2008 | Hotpoint 24 in. HDA1000Z Built-in...
DISK DRIVE
This would generally happen if the lens is dirty. You get special lens cleaning disks, however, you must read the user's manual before using any such disk. Some brands don't recommend the use of lens cleaning disks.
Apr 15, 2007 | Gateway 7210GX Notebook
Bush DVD142RC 14 in. TV/DVD Combo Logo
Top Bush Televison & Video Experts
Raj Patel
Tom Chichester
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
