HP Color Laserjet 5550 5550n 5550dn 5550dtn Duplex Network Laser Printer Q3715a Logo
i
iddrisu yussif Posted on Dec 28, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My printer hp color laserjet displays a printer error 57.07 i need to a process to clear the code
I tried using the blue brush to clean the fuser at the top of the black cartridge
Sebe Christian
Level 2:
Sergeant:
  • Expert 401 Answers
  • Posted on Dec 28, 2014
Sebe Christian
Expert
Level 2:
Sergeant:
Answers
401
Questions
8
Helped
72875
Points
960
Try looking up that specific error code and it should tell you what you need to do.
HP Color LaserJet Enterprise MFP M578. Error code 13.b2.ff.
Question edited for clarity 'make model error'.
Generic Paper Jam code for a jam in the fuser.
Video
Clear Paper Jam 13.B9, 13.B2, 13.FF Fuser - YouTube
https://www.youtube.com > watch
PREVIEW
1:05 No audio. Learn how to clear paper jams in the 13.B9, 13.B2, 13.FF fuser for HP Color LaserJet M65x, E650xx, E651xx and MFP M68x, E675xx, ...
YouTube · HP Support · May 19, 2020
HP LaserJet Enterprise M4555 MFP Printers - 13.B2.FF Error
https://support.hp.com > ca-en > document
Issue: A 13.B2.FF paper jam error appears on the control panel when paper is jammed in the top of the printer. ... Check the printer for jammed paper and clear ...
Missing: m578 ‎' Must include: m578
PREVIEW
HP LaserJet Enterprise MFP M577 - 13.B2.FF - PrintCopy .info
https://printcopy.info > code=13.B2.FF
HP Color Laserjet 9500 error 59.6Y What is this error and how to resolve?
Steps To Fix HP Printer is Displaying A 50.4 Error Message
  1. First thing you have to do is to cancel all the pending printing jobs in the queue.
  2. Now switch-off your printer and leave it for few seconds to cool it down.
  3. After cooling down the printer completely, the fuser failure error appears on the display screen.
https://www.hpprintersupportpro.com/blog/hp-printer-is-displaying-a-50-4-error-message/
https://www.laserprinterservices.com/hperrorcodes.html
HP Printer Error Codes HP Laser Printer Error Code 13.4 paper jam 50.1 Bad Low Voltage Power Supply 13.5 Paper jam in the fuser 50.2 Fuser Error 13.6 Paper jam in the fuser 50.5 Fuser Error 13.20 jam in the paper feed drive 50.9 Fuser Error
What does a fuser look like? hp cp4525 color laserjet? How to clear the error?
A 50.2 fuser error will on most cases require replacement of the fuser assembly. It is located on the right hand side of the printer. Same side as the manual feed tray. Open the door and look for two blue handles near the top of the opening.
1helpful
The hp colour laserjet cm6040mfp is displaying error 50.0 fuser error. pls i need ur assistance on it.
> FUSER ERROR
The FUSER is the part of any dry-ink laser-printer. It heats up, and melts the dry-ink onto the paper.
So, an ERROR indicates that the fuser is NOT reaching its "working" temperature.
Replace the FUSER, or take the printer to a qualified technician for remediation.
3helpful
I just replaced the Fuser Kit on the Office''s HP 5500 laser color printer but the error is still there and as in the instructions I never received the question: "Is this a new fuser...
Here is the instructions to reset the fuser maintenance count:
HP Color LaserJet 5500/5550 Maintenance Code Reset Instructions
  1. Press the ? button until the display reads "CONFIGURE DEVICE" and press ?.
  2. Press the ? button until the display reads "RESETS" and press ?.
  3. Press the ? button until the display reads "RESET SUPPLIES" and press ?.
  4. Press the ? button until the display reads "FUSER" and press ?
This should reset your printer and clear the error message.
I hope this helps, if so please rate my solution,
BuddyMc
Regularly getting error code 50.9 on a HP color laserjet 3550 printer
Hey Joe,
This is what the HP Website has to say about it:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
BUT! you can try performing a cold reset, and maybe this would help:
500, 3550, 3700, 4600, 4650, 5500, 5550, 8500, 8550, 9500) use the instructions below. 1. Turn the printer on.
2. When the memory starts counting on the control panel, press and hold the green SELECT button. Continue to hold green SELECT button until all three Control Panel LED's are illuminated and on solid.
3. Release the green SELECT button.
4. The control panel will display SELECT LANGUAGE.
5. Press the DOWN ARROW button until control panel displays COLD RESET.
6. Press green SELECT button. The printer will perform a cold reset and then continue its power-on sequence.
50,9 fuser error
Try reaseating the fuser asm in the back the printer. There is two blue unlock levers in the back that will unlock the fuser asm.
Take the fuser out and reseat the fuser asm, lock it back in place using the blue levers.
Turn the printer back on.
If the error still comes on then you may have an issue with the DC Controller board.
Error code 14.6
When the message 14.6 appears on the control panel display, change the coating pad and cleaning roller if an old-style fuser (C3111A) is installed. If a new-style fuser (C3969A) is installed, use the new coating kit (C3964A) instead.
Here is a link to detailed instructions...
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl70201&locale=en_US
4600 color replaced fuser get paper jam error
Check fuser for broken tabs that would engage sensors.
clean 3 sensors behind fuser with a blowerbrush or makeup brush.
make sure you did not break output full bin arm on back of fuser{happens a lot}.
need more help? just ask.
4helpful
3answers
Printer HP ColorLaserJet displays Fuser Error
My HP Color Laserjet 2600n Printer is giving me error as
" 50.2 Fuser error " . then every time i have to reatart my printer.
please give me suggestion.
thanks and regards.
ajinmumbai
k24674
Grand Canyon Tech
Grand Canyon Tech
