Question about HP Open Box Deskjet F4580 All In One Inkjet Printer Cb755b
How do I connect my new BT hub 4 wirelessly to my HP F4580 printer
Posted by Ronald Arnold... on
Vaibhav Dubey
    New Friend:
  • 12 Answers
Keep Pressing the BT hub button until the light continuously burn. Search your BT name in the printer bluetooth device. connect it using the PIN 0000.
Posted on Dec 28, 2014
How do I reset the ink level on HP F4580 printer
It automatically reset them when you install them & close the lid.
I’m happy to help further over the phone at https://www.6ya.com/expert/wynn_5ba0205233ebfc15
Dec 14, 2014 | HP Open Box Deskjet F4580 All In One...
How can I recover the password for my bt homehub 2
This page will show you where the default password is for all the BT Hubs. Where to find admin password BT Home Hub Help BT com Help If you need to reset the device as the password has been changed then look here How do reset my BT Home Hub to its factory settings Help BT com Help This will change the passwords to what are written on the BT Hub.
Oct 09, 2014 | AccessData Password Recovery Tool Kit (ftk...
Connect to Hp printer deskjet f4580
You can download the HP printer drivers from their support WEB site. Please click on this link and select your model printer to download :- http://welcome.hp.com/country/us/en/support.html
Dec 20, 2012 | HP Office Equipment & Supplies
Bt infinity installed and now hp 8500A printer not seen
You need to get the engineer back in there and fix it.
Jun 26, 2012 | Computers & Internet
Need to install my hp F4580 printer to my new net book...cannot use CD is there any other way?
I have two options that I can recommend for you.
1. Download the HP F4580 from the Hp website.
Here's the link: Click Here F4580 PRINTER DRIVER ...
It will take you to a screen which looks like this:
Select your operating system running in your netbook. Then select driver.. Then run it. Then follow the on screen instructions. After the installation, your printer will print.
2. The second option is to use an external dvd/cd drive. It could be connected to your netbook by using a usb cord. You can buy it from any computer stores..
I hope this helps.
Don't forget to leave your comments and ratings for your free technical support in fixya.
Thank you for using fixya. Have a good day.
Carlo
Sep 25, 2010 | HP DeskJet F380 All-In-One Printer
My printer has stopped communicating with our BT home hub It was OK and the security code is correct it just cannot establish a connection. I tried it with the previous Netgear wi fi and it connects just...
you can also change the BT home hub 2.0(black)encryption type to WEP type. all you need to do is follow the steps to change the type of encryption to WEP.
  • connect a computer using the ethernet cable to the hub(its the black cable with yellow leads).
  • open an internet explorer or anyother browser, in the address bar just type 192.168.1.254.
  • you will be getting the BT home hub manager page with please reset your password, asking for three credentials.
  • in the first bar enter the default admin password or the admin password which is found in the wireless card or at the back of the home hub in the label. in the second and third bars enter the password of your own, something like admin1.
  • you will be getting another page coming with four options at the top (home, services, settings and troubleshooting).
  • click on settings, and below troubleshooting in the blue bar itself , you will see advanced settings. click on it.
  • then click on continue to advanced settings, now below home in the blue bar itself, click on wireless.
  • after you do that, you will see two options called as configuration and security. click on security. there you will see the option to change the wireless encryption to WEP.after changing the type to WEP, type the same password again in the section for password and click on apply to save changes.
  • check whether your printer is connecting to your home hub after that,
I am a person who work for BT in the tech help desk dept. if you have any trouble in doing this please reply to this message
May 19, 2010 | Kodak ESP 5 Printer
Can I connect my HP PSC1510 to my BT Homehub v1?
yes, you can. I have my printer connect to my hub and my desktop and I can print from my laptop wirelessly.
You will need your all in one connected via a printer or USB cable to a computer AND also connected to your hub. Then, go to the computer that is connected through a cable to the all in one. Your all in one should have some way to configure its IP address. I have my printer configured as 192.168.1.4 and it's plugged into the 4th port of my hub. Check if this works.
Mar 14, 2010 | Acer Aspire One Netbook 8.9" Notebook
I have a BT 2-wire hub with networked printer.
First thing, Does your printer have a wireless facility built in? If not it has to be connected to the hub with ethernet.
Normally setting up a wireless printer involves using cables until the set-up is complete. It's nothing to do with the router but all to do with the printer.
Best thing is to go through the manual.
Oct 14, 2009 | 2wire (1000-400108-001) Router
Unable to connect wirelessly to my Samsung CLP 315W
configure the setting manually by putting the printers IP address....install the driver first
verify your printers support site and download the updated/new drivers and patches need to install.
link for Drivers and manual:
http://www.samsung.com/us/consumer/detail/support.do?group=printersmultifunction&type=printersmultifunction&subtype=colorlaserprinters&model_nm=CLP-315W&language=&cate_type=all&dType=D&mType=SW&vType=&prd_ia_cd=06010200&disp_nm=CLP-315W&model_cd=CLP-315W/XAA&menu=download
Mar 20, 2009 | Samsung CLP 315 Laser Printer
HP Open Box Deskjet F4580 All In One Inkjet Printer Cb755b Logo
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
