Question about Riccar Vacuums
Burning smell when running - Riccar Vacuums
Posted by Carrie Adams on
HFCoombs
    Habit-Forming:
  • 98 Answers
Filter is plugged maybe but burning smell is something over heating like a motor which should be serviced by a pro.
Posted on Dec 28, 2014
Burning smell Kenmore 50558
If the burning smell is an electrical smell it could be motor or wiring problems which are best handled by a professional. If it smells like burning rubber it is probably the belt. If it smells like burnt wood it could be the belt slipping on the brush roll, if the brush roll is made of wood. Dust and debris can also accumulate behind the end caps of the brush roll causing friction which can cause a burning wood smell.
Mar 30, 2014 | Kenmore 5055, 50557 and 50558...
Hoover carpet cleaning started to smell like it's burning and black chunks of rubber came out
Nan, there's obviously a belt that's shot and needs to be replaced. If it started to smell, then it was probably bound up at some point in it's travel path, that stops it from running and the motor shaft burns it's way through the belt, making the smell.
Nov 03, 2013 | Hoover SteamVac Carpet/Upholstery Deep...
How do I get rid of the bad smell coming from my filter queen
Change all 4 of the filters, and wash the dirt container with soap, water and a little bleach. The only other thing that would cause a bad smell would be the actual motor, but that would be more of a burning smell. Good luck!
Jan 25, 2012 | Filter Queen Majestic Canister Vacuum
Runs, Smells like it is burning up
If it smells like burning rubber then it's possible that the belt is broken.
Feb 11, 2011 | Hoover U5753-900 WindTunnel Bagless...
When running it smells like something is burning
Hi
If it smells like burning rubber, then your belt is probably slipping due to having lost tension and needs to be replaced. If it's another smell, it could be the motor burning out, but that is often accompanied by smoke. There could also be something caught around the revolving brushes in the cleaning head. Lie the vacuum on it's side and make sure you can spin the brushbar freely by hand. Also check for any debris entangled in or obstructing the brushes. This would also cause the belt to slip resulting in a smell of burning rubber. It could also damage the motor so I suggest not using the vacuum until the source of the fault has been determined.
Instructions on replacing the belt can be found in your user manual. If you don't have one or need further instruction on how to do this, please post back for further assistance.
Regards,
BElectric.
Nov 25, 2010 | Eureka Capture Upright Vacuum Vacuum
Vacuum smells like something is burning
Ok...Check the brush roll is free not sticky..Next is the belt okay, not jamming on the brush roll making the burning smell...You could take off the roll and run motor on its own ..finding out if its the motor..
Apr 13, 2010 | Bissell Healthy Home HEPA Bagless Upright...
Smells like burning rubber when I turn on my G6 Kirby vacuum.
You must take of the plastic ends from the wood beater bar and make sure the metal axels are not wound up with hair. I did this monthly with 4daughters
Feb 15, 2010 | Kirby G4 Bagged Upright Vacuum
Kenmore vacuum model 116.3592250 works fine, burn smell
is that the one with the direct drive brushroll? those brushroll motors inside the brushroll always go bad. that is one of the worst designs from kenmore. is the brushroll turning?
Dec 31, 2009 | Vacuums
My Hoover Wind Tunnel has a burning smell when running. I replaced the belt, but this didn't help.
its clogged my vax does that burning smell when it gets clogged up thats for the five minutes before it overheats and stops
Aug 03, 2009 | Hoover U5753-900 WindTunnel Bagless...
Burning Smell
Check the carbon motor brushes, there might be arcing on the armature. New brushes may help if the armature is ok.
Mar 29, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
103 people viewed this question
Top Riccar Vacuums Experts
brian kossman
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
