Question about Technics SL-BD20D Turntable
Turntable output level too low and plain compared to CD, etc.
Hello and thanks in advance for any comments you may have.
I have a Technics SL-BD20D Turntable connected to the phono input on a Yamaha RX-V1700 Receiver. The analog sound level coming from the turntable is probably about 25% lower than that of my other components including DVD, CD and cable boxes (all separate components connected via HDMI, coax and RCA cables). The sound is also quite plain and lacks low end punch. The high frequencies are fine and have enough air but overall my brand new 180g vynil lacks the richness of sound I am expecting from it. I adjusted the volume trim on the phono input to +6dB which improved the level issue a bit but the bass is still missing and now the level is say 15% lower than that of the DVD player.
The turntable still has the factory installed cartridge and I suspect it is part of the problem but is that all that I can get from it?
Thanks again!
Posted by ezafirov on
  • ezafirov Jul 07, 2009
    Thanks. I specifically picked that $1,300 (two years ago) Yamaha model for its built in phono input capabilities... So no chance to 'cheat' with a more 'efficient' cartridge? If the answer is negative, is there an optimal, in your opinion, pre-amp - I would not like to introduce a week link in the chain by adding a sub par pre-amp, however you can see that I bought a somewhat nice amp and not so nice turntable... Given all that, what would you buy?
Frank Fulton
    President:
  • Technics Master
  • 1,114 Answers
Get an external pre-amp. They range in price from 25-100 and more, depending on the capabilities. All over Ebay, and electronics sites. That will fix your problem. Hope this helps
Posted on Jul 06, 2009
I recently purchased an onkyo tx-nr626 receiver with phono input. When playing albums , I don't get full sound. Sound is clear but not full and loud.
Different cartridges put out various levels based upon their technology - make sure you are using the proper input for their output. A line level input 1V P-P won't work on most phono cartridges and will require a preamp to boost it to the higher level.
Dec 23, 2013 | Technics SL-BD20D Turntable
I recently purchased an onkyo tx-nr626 receiver with phono input. When connected I don't get full sound.
I have a Technics SL-BD20D turntable and want to connect it to a Technics SA-EH50 amp. Can this be done. Please tell how
Hi, you need a preamp to boost the line level if no dedicated phono input is on amp. Cheers John. Styluscity
Dec 28, 2011 | Technics Audio Players & Recorders
Cannot hook up sound to surround sound , everything else works, cd player, radio, tapedeck. just the turntable does not work. any suggestions? deb
Hi, you need to connect the turntable to your amp via a phono input connection. If no phono input available then a pre amp needs to be used between turntable and amp to up the signal. Cheers John. [email protected]
Sep 28, 2011 | Technics SL-1200MK2 Turntable
I dont have the orginal ground wire for my Technics SL-BD20D turntable someone told me i could use rca cables to ground it, i have a pre amp cause my main amp didnt have phono jacks on the back of it.
You don't need the original ground wire for Technics SL-BD20D turntable,
any plain cable can be used for this purpose...
you should connect turntable to your pre amp,should be a "phone" input at the back...
here are some suggestions for grounding....
  • Plug in a surge protector to the outlet, and then plug all the components into that surge protector
  • Connect a ground plug to the surge protector and then plug the ground plug into the main outlet. A ground plug is available at any hardware store, and turns a three prong connection into a two prong. Ground plugs help eliminate 60 cycle hum.
  • Connect the ground wire from your turntable to the ground wire connection on the receiver. If this doesn't work, looking on the back there should be a grounding point,
    Unplug your receiver.. Split a wire and attach one of the splits to the receiver where you will see the text, "ground" or something similar. Attach the other end to something metal such as a pipe that goes into the ground. Secure with electrical tape. Plug in.
    connect the ground wire to a screw on the electrical outlet.
    Take care and please Remember to rate/vote and give me 4 Thumbs Up
    for Helping out the Community :)
    Hope this helps!
    Jun 22, 2011 | Technics SL-BD20D Turntable
    How do i connect technics turntable model SL-QD33 to technics stereo model SC-DV290 and what do i need to switch to on stereo to play records.
    Have a look on the back input panel of the sc-dv290. Check for a "PHONO" input. If there is no phono input it will not play turntable. If there is: then plug it the turntable in and switch the SC-DV290 to PHONO mode.
    Another way would be to purchase a "phono preamplifier" from ebay: Hook the turntable into the phono preamplifier, and the preamplifer into the SC-DV290 AUX input.
    Feb 26, 2011 | Technics SC-DV290 System
    Buzz coming from speakers on phono input
    is the wire loose on either end? sometimes the electrical plugs can cause noise due to resistance, so trying different outlets might help too
    Jun 21, 2009 | Technics SL-BD20D Turntable
    SL-BD22 SETUP
    go to RADIO SHACK and get a pre amplifier module (hope its still available) , that will do the trick , AJ
    May 20, 2009 | Technics SL-BD22 Turntable
    Connecting a Technics SL-BD20D turntable to a Yamaha RX-V463 Rece
    After further research, I learned that I need to plug the turntable into a preamp before plugging it into my newer receiver. As with cassettes, record players are fading away. I ordered a preamp, but won't be able to experience success until it arrives.
    Jan 16, 2009 | Yamaha RX-V463 Receiver
    Technics SL-BD20D Turntable Logo
    629 people viewed this question
    Top Technics Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Marvin
    Marvin
    Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
