Question about Sony Radio Communications
When someone calls me, the beep on my sony mbh20 bluetooth is very very low
The beep on the bluetooth that notifies you that you have a call is very very low
Posted by Margie on
4 Related Answers
Anonymous
SOURCE: bluetooth
i would like to buy one what advice
Posted on Jan 24, 2008
Anonymous
  • 42 Answers
SOURCE: Phone keeps beeping after incoming call is rejected
If you go to Menu->Settings->Tones and then choose Notification and change that setting to silent, then I believe your pesky beeping will go away. It's something to try anyhow.
Posted on Apr 15, 2008
Anonymous
  • 17 Answers
SOURCE: How do I get my Samsung WEP475 bluetooth to notify
it make a higher piched bbep when reciving calls. reference wit company
Posted on May 13, 2010
ameliawang93
wwlvictoria
  • 1001 Answers
  • Smooth call conversation and non-stop and clear music streaming creates enjoyable listening experience
  • Universal Compatibility: Fully compatible with iPhone, iPod, iPad, Tablets, Other Smartphone, most speakers, TV, and radio, easily plugs into any powered PC speakers, Car & Home Stereo Sound System.
  • Small and Simple: Its outline feels like a mini iPhone 6, petite and charming, it doesn't need much space in your car; Simple design, easy operation, you can get away from complicated operation of some other Bluetooth receivers.
  • Charm sonic bluetooth audio receiver into your car AUX port or home stereo sound system,then you can enjoy your music time.
Amazon com Charm sonic Wireless CSR4 0 Portable Bluetooth Receiver...
Posted on Jan 06, 2017
How do I raise the volume on my sony mbh20 bluetooth
I don't see any volume rocker button on the unit. Raising volume from the phone itself will be the solution. Did you try that ?
3answers
Try the following and let me know if this doesn't work and I can try to figure it out but from other complaints about this phone, everyone seems to have this problem and it may be unfixable, just might be the programming
Thank you for using Fixya and Good luck on getting this fixed.
Cannot hear phone ringing in headset, only on handset.
The HL10 handset lifer is what notifies your headset that you have an incoming call. If you are using the handset lifter and are not receiving the 3 short beeps in your ear piece there are a couple different things that could be going on.
1. The internal microphone could have gone out on the lifter. This microphone is what sends the signal to your headset that you have an incoming call. If the microphone is working you will hear 3 short beeps in your headset.
2. If the volume is too low on your telephone, the handset lifter will not notify the headset of an incoming call, so try turning the volume up on your phone and see if that takes care of the problem.
3. The HL10 handset lifter ships with a ring detector that has a 2.5mm jack on one end and a small round microphone on the other end. This ring detector is intended for phones that do not have the speaker located under the handset. You could try plugging this into the back of the lifter and setting the microphone next to where the lifter is mounted on your phone. This might help pick up the sound of the phones ring tone.
If you are manually lifting your handset out of the cradle and sitting it to the side instead of using a lifter, then you will not receive the 3 short beeps in your earpiece to notify you of an incoming call.
Good luck from Headsets Direct!
Parrot v508c
Turn off key word voice prompts/voice commands. The Parrot is listening for key words like "phone" or "call" or "hang-up". When it thinks that it hears this it will beep, or call someone.
To add bluetooh headset
i have a bluetooth head set but when my phone ring's no music to head set only beep beep beep
Bluetooth
Radio Communications Logo
Top Sony Radio Communications Experts
 Grubhead
Grubhead
durantheman
Dennis
Are you a Sony Radio Communication Expert? Answer questions, earn points and help others
