Its 15"6. its really good and screen is good quality it is just the sound that doesn't work and that is a big problem for me.
SOURCE: Medion Akoya Multimedia notebook - wireless capability
I believe on the medion you have there may be a switch on the front or side to turn on the wireless. That or FN key and F1.
SOURCE: I have medion akoya s5610 laptop. Power light
Before starting a sometimes time consuming
troubleshooting process, make sure you've turned on every
power switch
and power button on your computer:
Note: If you have a multimeter or another electrical testing device
you are welcome to use that to test your wall outlet (and power strip, surge
protector, etc.). The lamp test is useful if you don't have an electrical
testing device.
Replace your power
supply if it fails your testing.
Important: In the huge majority of cases when a computer isn't
receiving power, a nonworking power supply is to blame. I bring this up again to
help stress that this troubleshooting step should not be skipped. The next few
causes to consider aren't very common.
Replace the power button if it fails your testing.
SOURCE: medion akoya e1210 notebook. failure to boot pxe
Failure to boot PXE 061 is a BIOS message that indicates 2 things:
The apparent problem is failure to boot to the hard disk. If the system was running yesterday and there have been no hardware changes to the system, then most likely failures are:
Testimonial: " many thanks will get it looked at"
