Question about Electrical Supplies
How to fix my generator
When I start my generator it runs at full throttle an
Posted by Melvin Harmon on
Rick Johnson
    Scholar:
  • 84 Answers
Generators are designed to run at full throttle, for optimal power output.
Posted on Dec 26, 2014
Honda generator eu3000is Not getting power to carb in order to meter fuel
After reading about Honda's Eco Throttle system available on inverter generators it seems it is not a fuel metering system but a computer controlled speed regulator or basically an electronic throttle.
Because the engine of an inverter generator doesn't need to run at a constant high speed to produce the correct 50 or 60 Hz output this generator can run at slower speeds when the load is light. The electronic throttle is the means to make it happen - operated by the computer.
The throttle is probably operated by a stepper motor and the power supplied to it likely to be in digital form. I suggest you try and gain a more full account of how the system works before you delve deeper.
Nov 09, 2017 | Honda Electrical Supplies
Honda EM5000SX generator - will not idle up when a load is placed on. Will produce power but will not idle up.
from your description and what you do , the problem is in the auto control unit
it will be in the system to reduce the rpm to idle when there is no load ( auto mains on off controller switching between genset and mains supply)
by turning the auto operation off you are committing the gen set to full rpms regardless of the power requirement
you have the option of having it fixed at an gen set repair shop or leaving it off and starting the genset only when you have a mains power outage
check with an electrician to ensure that it is possible to run it that way as if the mains power unit is not correct , when you start it and you still have mains power , it will destroy the gen set
Dec 13, 2016 | Honda Electrical Supplies
5500 watt generator will not run my 2hp air compressor
5500 watt generator will meet the 1491.4 watt requirement of the 2 hp compressor motor
given that 5500 watts generator is rated continuously at around 4500 watts and will handle spikes to the 5500 watts when electrical components start there should be plenty left
consider the possibility or a motor below full capacity, carby problem ( jets blocked , water, blocked air filter not getting full throttle from the governor lever, worn rings, type of fuel in use --E mix)
Nov 18, 2015 | Electrical Supplies
Generator running full throttle
Most generators, when started, will run at full throttle. This will allow them to pick up load quickly.
Mar 11, 2014 | Yamaha Electrical Supplies
Why it want make electricty are load up?
Must be up to full running RPM to generate the right operating voltage. If it is running at full throttle and there is no power out, then the generator head needs to be repaired.
Feb 06, 2014 | Coleman Electrical Supplies
Coleman Powermate full throttle
There may be a choke handle that should reduce the engine RPM. Otherwise contact the Coleman technical support department.
Dec 22, 2013 | Coleman Powermate Powermate 5000W...
How to start the generator
Hi Joe, I had asked for a little clarification and have not received any information. I will answer this question based on the generator is in good working order and it is a recoil start. Open the petcock, (this is the fuel valve) and give it about a minute to fill the fuel bowl on the carburetor. If your generator has an engine an on/off kill switch, set to on. If the generator has an auto idle switch set it to off. If the engine has a throttle lever located under the carburetor, push it all the way down (full throttle). Pull the choke knob out completely, there is a detent on the choke for half choke, pull it past this for full choke. pull the recoil starter rapidly. As soon as the engine starts running push the choke knob to half choke, this will allow the engine to run smooth while it's warming up. Depending on the climate that you are in, warm up time will vary. After a minute or two in cold climates start pushing the choke knob in, if it starts to run poorly pull it back out too the half position and let it warm up some more. When you can posh the choke in without the engine faltering it is ready to go. In warmer climates you might be able to start the engine without the choke or in the halfway position. Robin Subaru makes some of the finest small engines available. I would choose a Robin over a Honda every time. I hope this gets your generator going, and once again this is based on the generator being in good working order. Good luck, Michael Burke.
Dec 03, 2011 | Coleman Powermate Subaru 5000W Portable...
Throttle on generator question
The idle control switch allows the generator to go into idle when there is no demand form the appliances connected. This saves gas and increases the life of the generator. Damage can occur for some appliances like a refrigerator/freezer because the voltage and frequency are not prepared for the load resulting in a low voltage bad startup that will damage the appliance. Suggest that you leave the idle control switch off while any motor/electronic devices are connected.
The throttle control is likely a choke function for starting. These generators are designed for only one running speed to produce the necessary 60 cycles per second and voltage.
The following link is to a Canadian web site that later in the detail report describes the concern of idle control. In addition it provides good insight to the operation and use of portable generators
Hope this helps?
Understanding Portable Generators
The user manual see pages:
http://www.mikestools.com/download/Porter-Cable-Manuals/Porter-Cable-CTE300.pdf
May 06, 2017 | Porter Cable Portable Generator BSV750
Homelite Lightnin Bug Generator not getting gas
try leaving your choke partially on it may not be getting all the gas it needs,see if it will run then, it wont run full throttle, but this will tell you its not getting enough gas
Oct 05, 2009 | Electrical Supplies
Fuse blows repeatedly
The auto speed control is failed. Keep it manual and see how it does...It will run at full throttle even when no load is running. Then fix the throttle control when able.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 09, 2009 | Generac Guardian Ultra Source 15,000 Watt...
Electrical Supplies Logo
52 people viewed this question
Top Electrical Supplies Experts
Marvin
Marvin
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
