Ovens Logo
Question about Magic Chef Ovens
My Chef Classic Wall mounted fan forced oven stopped working. Its grill section working. Fan and the light in the oven working well. Bot oven doesnot heat up. Please give a tip what is probably wrong?
It is Chef Classic Wall Oven
Posted by Tilak Jayawardena on
Tom
    Sergeant:
  • 314 Answers
The bake element has gone bad. They can visually look fine but still be bad. To check and replace that element you will unfortunately need to kill the power and remove it from the wall. Remove the back cover. Check for a low resistance (around 16 ohms) across the bake element. If the resistance is high the element is bad. Google the make and model for a replacement element.
Posted on Dec 31, 2014
  • Tilak Jayawardena
    Tilak Jayawardena Dec 31, 2014
    Thanks very much.
  • Tammie Apr 13, 2015
    Did this solve your issue? I have the same one.
Are fan forced ovens meant to have hot air coming out from the top of the door? I have a built in chef fan forced wall oven
Unlikely there would be no air spilling through the door seal because it is an oven and not a watertight compartment. An oven door seal needs to be hard wearing and able to withstand high temperatures and hot grease which limits the materials used, that and the fact few domestic oven doors actually latch these days but are held closed by springs meaning the pressure against the seal is relatively light which means the door, the shut and the seal must be manufactured to a high degree of accuracy and properly adjusted.
If the amount or air leakage is excessive perhaps the door could be adjusted or the seal replaced. Try asking around to find someone with a similar oven so you can compare...
Feb 11, 2018 • Ovens Ovens
1helpful
Chef Norfolk Deluxe fan forced oven. Oven, lights and separate grill - all lights went out, lost heat and stopped working.
there is a fuse inside the plug,unplug it to check it,please report the other posts
Jun 15, 2015 • Ovens
1helpful
I have a fan forced chef classic wall oven and the fan has stopped working....why ould this have happened/
There has several reasons the fan could have stopped working:
-It is possible the fan wiring/connections have become loose or unplugged
-It is possible that the fan motor has worn out or become jammed over time due to debris
-If you recently cleaned your oven, the fan could have stopped working if it came into contact with any caustic oven cleaner.
Hope this helps.
Feb 28, 2011 • Ovens
3helpful
Not heating in fan forced mode
Possibly your fan element has blown. Try and take the cover off that coves the fan inside the oven itself and use a torch to look at the element to see if it looks out of shape etc.
58helpful
3answers
Chef classic wall oven with digital clock change time?
Press the TIMER button (the leftmost one with a little bell icon) and the "cooking" button (the one next to it with a "hot saucepan" icon) briefly at the same time. Within four seconds start changing the time with the + or - buttons. When you have the correct time just leave it and it will leave time setting mode four seconds after the last button press.
Apr 12, 2009 • Ovens
Smeg oven
How long is the oven in operation before you check the air flow ? Most Smeg ovens are electronically integrated and sensitive.
Jan 24, 2008 • Ovens
Top Magic Chef Ovens Experts
Marvin
Marvin
vince
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
